Illuminated kick plate/door sills stopped working
Old Mar 9, 2018 | 08:13 AM
Jakeklim's Avatar
Jakeklim
Question Illuminated kick plate/door sills stopped working
Hi all,
my G came with illuminated door sill / kick plates and they just both went out so I’m assuming it’s fuse rather than lighting issue. I checked both fuse boxes and non were open. Since I didn’t do the install, I’m not sure how to proceed. Any advice would be greatly appreciated. 2013 G37x - I have the original battery and read that disconnecting it for 5 mins would reset the BCM which may be my next step.
Old Mar 9, 2018 | 09:36 AM
iCrap's Avatar
iCrap
They plug into the BCM near passenger footwell, right side. So check there.
Old Dec 15, 2020 | 06:10 PM
Majd Kamal's Avatar
Majd Kamal
Did you find the problem
Originally Posted by Jakeklim
Hi all,
did you find the problem
cuz I have the Same issue
Old Dec 16, 2020 | 10:39 AM
BULL's Avatar
BULL
Moderador
Hi all,
If you guys have access or knowledge of a voltmeter you'll need to start from there.
It's possible that the main harness for it might have gotten pinched/disconnected or corroded and is not providing the voltage or ground the sills need.
A voltmeter will determine if it's power or ground that you're missing. Without this info there only so much we can recommend.
Old Dec 16, 2020 | 10:50 AM
ILM-NC G37S's Avatar
ILM-NC G37S
The illuminated kickplate T-harness has a inline fuse that needs to be checked. The fuse is the old timey glass tube type and is usually located inside a white, hard plastic case. It will be very close to the BCM and likely wrapped in foam tape.
Old Dec 23, 2020 | 05:09 PM
jpowersjr2's Avatar
jpowersjr2
Also make sure you don't have water around your BCM from a clogged sunroof drain.
SepaG
Jun 24, 2024 09:45 PM
milosz
Aug 11, 2019 09:40 PM
roman9404
Mar 2, 2015 12:05 PM
BeefMaster
Dec 10, 2013 02:22 PM
msmching
Dec 8, 2011 05:15 PM
