Lighted door sills do not light...?
I bought a 2013 G37x 4 door in October 2016. Been a great car. Had no problems with it.
The car came with those illuminated " I N F I N I T I " door sills in front. I can't believe someone paid $400 for that, but OK, it was on the car when I got it.
They used to light up when the door was open. No longer lighting up, either side. Any ideas where to look? Doesn't seem like something that would have it's own fuse, and nothing else has stopped working. The dome lights etc all work OK.
Anybody else experience this?
It's not a big deal, but if it were a simple fix, I'd fix it.
I just hope it's not the start of some kind of electrical poltergeist activity.....
You will have to remove some trim panels to access the BCM (passenger side kickpanel under dash and locate the "T-Harness" that is for the kick plates. The fuse holder is the white plastic "capsule" about 2" long (approx.).
Hope this helps.
Thanks for the info. Seems like more trouble than it's worth to dig around under there, remove trim panels etc, just to have those things light up. I suppose if I get ambitious.....
But - THANKS FOR THE INFO! Tells me exactly where to look.
>>.,,,checking that area for water intrusion,,,<<
Oh, yeah. That's good advice. I'll have a look.
THANKS AGAIN!!!!!!!!!!!!
Jamsey Aimsey
04-17-2015 07:30 PM
Calvin
Picture Share G Coupe
07-18-2009 04:21 PM
