Complete Headlight Bulb Exchange
Old Jul 25, 2013 | 11:15 PM
Sway's Avatar
Sway
Lightbulb Complete Headlight Bulb Exchange
Swapped out stock bulbs in the headlight assembly for the following:
- 6000K Xetronic D2S headlights
- Triton V3 6000k Switchbacks (driving light / turn signal)
- V-led 6000k Parking lights
Vids:
Headlights (xetronic on driver's side) / Driving Lights (turn signals) / parking lights
Driving Light (turn signal) / parking light
Switchback Turn Signal Comparison
Pics:
Switchback on driver's side, stock on passenger's side.
Switchback & parking light from V-Leds
Notes: Nevermind the noise of the fountain... When changing bulbs, Turn wheel and take off pop nails. expect hand bruises.
Old Jul 26, 2013 | 03:18 PM
Yan141's Avatar
Yan141
looks good....Where u bought it from? link please
Old Jul 26, 2013 | 03:36 PM
11SAPG37's Avatar
11SAPG37
What did you do about the hyper flash? I cant figure it out..
Old Jul 26, 2013 | 04:58 PM
Sway's Avatar
Sway
Flasher is built into the V3 triton. Get the entire system from them. I put red ones in my rear turn signals as well.
Old Jul 26, 2013 | 05:08 PM
Damn Dirty Ape's Avatar
Damn Dirty Ape
I was contemplating getting the v3 triton in the switchback for my coupe. I would like to ask here, the white switchback part is not always on when the car is running is it?
What I was wanting to do (might not be possible) was to get the v3 switchbacks, put them in the coupe turn signals and have them run white as DRLs, then if the turn signal was hit or flashers they would turn amber.
I think my sticking point will be getting them to run white all the time since the turn signals are only powered when they are used for signaling, correct?
Old Jul 26, 2013 | 05:31 PM
Sway's Avatar
Sway
They are NOT drls. Have to turn them on. it's possible to have just the driving light (turn signal) and parking light on in the front of the vehicle, however this turns on your dash lights and tails/ license plate as well.
Old Jul 26, 2013 | 05:51 PM
Damn Dirty Ape
ok I wasn't sure if these could be used as such. thanks for the clarification.
Old Jul 26, 2013 | 09:17 PM
SlimTV's Avatar
SlimTV
How do the new bulbs compare to stock as far as visibility and light output? Is night time or low light visibility the same, less than or greater than stock? Also how much were the headlight bulbs?
Old Jul 26, 2013 | 10:04 PM
Sway's Avatar
Sway
More than you can afford pal... Jk. Got the xetronics from xtralights.com
xetronic 6000k D2s
The light output seems lightly increased only because the switchbacks are so bright. The color reflection off the asphalt however looks sweet. The color match is pretty Uniform from all 3 bulbs...
Old Aug 1, 2013 | 08:31 PM
rpkg37xs's Avatar
rpkg37xs
on the v3 how many of the screw did you use to mount them and did you connect the dimmer wire? thanks
Old Mar 4, 2014 | 04:50 PM
Mik3G37S's Avatar
Mik3G37S
Were the V3 switchbacks pretty much plug and play ?? is there a resistor required for those?
Old Mar 4, 2014 | 04:57 PM
connoisseurr's Avatar
connoisseurr
The resistor is built into the base of the switchback. That's why you pay out the wazoo for them. And they're really bright from what I've seen.
Old Mar 5, 2014 | 06:45 PM
Mik3G37S's Avatar
Mik3G37S
that's awesome then , well they are expensive but for the quality and light output they provide I guess they are well worth it... and will replace my current 5000k LED switcbacks from VLEDS that aren't as well visible in daylight as I would want them to be !
Amaadkhan2k
Oct 11, 2015 11:52 AM
mahadeod
Oct 6, 2015 01:02 PM
TheIvoryG
Sep 23, 2015 02:06 AM
pauliewalnutzz
Sep 8, 2015 11:41 AM
