Help 2010 g37x sedan
Old Apr 21, 2013 | 01:11 PM
angeljr8282's Avatar
angeljr8282
2010 g37x sedan
Hey guys I want to swap out my fog lights bulbs but I don't know how I look under the bumper I'm not sure if it those 4 bots thanks
Old Apr 21, 2013 | 01:33 PM
WhiteG_'s Avatar
WhiteG_
Those 4 bots?
Are you just wanting to switch out to new halogen bulbs? Are you wanting to convert to HID? Or LED? Kinda lost me with your original post, kinda confused on what you are asking.
Old Apr 21, 2013 | 01:48 PM
angeljr8282
Sorry I pick up some nokya yellow halogen bulb 35watts and I'm trying to swap them out just don't know how
Old Apr 21, 2013 | 01:54 PM
WhiteG_'s Avatar
WhiteG_
I just un-bolted a few of the under shroud bolts directly underneath the fogs, reached up there and pulled them out. Swapped them for HIDs, install took a total of 20 minutes for both bulbs.
Old Apr 21, 2013 | 02:12 PM
angeljr8282
OK so its those bots under the bumper right...i have to remove all of them
Old Apr 21, 2013 | 02:34 PM
WhiteG_'s Avatar
WhiteG_
Just remove enough to reach up there and grab a hold of the bulb, twist, and it comes right out. There should be enough slack on the wiring where you will be able to see/maneuver a new bulb up there with no problems. Worse comes to worse, you can remove the wheel well cover to get a better visual. That is still much easier than removing the bumper.
Old Apr 21, 2013 | 03:06 PM
angeljr8282
Yea I was thinking about removing the wheel well it looks easy that way Lol thanks bro
Old Apr 21, 2013 | 03:18 PM
WhiteG_'s Avatar
WhiteG_
no problem, good luck!
Old Oct 18, 2014 | 04:40 PM
tite_tite's Avatar
tite_tite
Hi,
2010 G37 Sedan
I was able to change the driver side fog light bulb but the passenger was different. Can you advise on how to change the passenger side?
Thanks.
Old Oct 25, 2014 | 03:56 PM
tite_tite's Avatar
tite_tite
Originally Posted by tite_tite
Hi,
2010 G37 Sedan
Thanks.
I was able to install the passenger fog light. I had to remove the panel on the bottom of the car at front of bumper & sneak your hand in there to remove & install fog light. This is for 2010 G37.
If I knew I can do this, I would have done it for the driver side as well. Also, the 2010 fog light bulb is H8 not 9006.
Hope this helps.
tom_lom
Jun 30, 2021 07:52 PM
m3clubracer
Sep 11, 2016 09:01 PM
drewfinity
Sep 8, 2015 09:10 PM
drewfinity
Aug 20, 2015 08:17 PM
DevinKoolie
Aug 11, 2015 06:47 PM
