How to take off top light to replace bulb?
Old May 7, 2012 | 10:01 PM
nickw's Avatar
nickw
Just as the title says I'm looking to switch it with an LED, Can I just pop the light cover off or do I need the take the entire top apart, like with the sunroof controls and both lughts / sunglasses holder. Thanks guys.
Old May 7, 2012 | 10:16 PM
nickw's Avatar
nickw
I also just tried taking off the cover from my license plate blubs and they are very very hard to get off, to the point where i was cracking the plastic, should it be that hard?
Old May 8, 2012 | 12:41 AM
awais's Avatar
awais
You just need to take the cover off. I use a credit card (or any other card) to pry it off and it doesn't leave marks.
Old May 8, 2012 | 12:45 AM
awais's Avatar
awais
Squeeze the sides of the license plate bulbs housing and you should be able to pull them out one at a time. Turn the bulb counterclock wise to remove it from the housing. Should not take any force at all really.
Old May 8, 2012 | 08:25 AM
Rad_Slinger's Avatar
Rad_Slinger
The license plate bulb housings come off by hand by pinching the two little tabs towards the center of the housing. You should NOT be cracking anything.
The map lights have a tab on each corner of the covers (the white covers n either side of the SR control). You can use a butter knife or some other flat/thin instrument and gently pry each of them out one by one.m y don't have to take the entire thing apart.
Old May 8, 2012 | 09:44 AM
2008G-Man's Avatar
2008G-Man
Bulbs just pull straight out, no twisting ... they are 194/168 base. None of the covers should be that hard to get off.
Old May 8, 2012 | 09:59 AM
nickw's Avatar
nickw
Thanks guys, going to put them in on my break.
superjoey
31
Mar 22, 2023 11:56 PM
Ricio1991
Aug 23, 2015 10:44 AM
Spicy_Kimchee
Aug 11, 2015 09:10 AM
dAgent
21
Aug 6, 2015 02:15 PM
