plasti dip question
Old May 16, 2011 | 12:39 PM
sniper27's Avatar
sniper27
plasti dip question
So I've read about a hundred threads about plasti dip and decided to give it a try this weekend cuz i was bored. My question is, how did you apply it?
Light coats from far away (8-12 inches)
Heavy coats from up close
I did my grill using light coats from far away, applying about 5 coats, and it didn't turn out as much as I liked. The texture was not very smooth with uneven spots (some area looks shinier and smoother than others). I tried peeling it off and it didn't come off easily as others described. I may try this again, but any tips would be appreciated.
Thanks.
Old May 16, 2011 | 12:45 PM
chuckie311's Avatar
chuckie311
Drop A Gear and Disappear
i did mine about 8 inches away light coats to start and the last few coats alittle heavier mine turned out fine..
Old May 16, 2011 | 01:28 PM
soolman32's Avatar
soolman32
You want to go with lighter coats from about 6 in away. If you go too heavy from close up it will run and look pitted. Remember to spray from left to right and vice versa for even application. Let it dry between each coat.
Old May 16, 2011 | 01:32 PM
simpson_G37X's Avatar
simpson_G37X
for future reference, this is the easy way to remove plasti dip:
https://www.myg37.com/forums/d-i-y-i...-easy-way.html
Old May 16, 2011 | 02:49 PM
CDONNS's Avatar
CDONNS
Haha, you love pimpin out your DIY any way possible.
Old May 16, 2011 | 03:22 PM
simpson_G37X
well i know many people have had problems with removing it haha thought id help
Old May 16, 2011 | 05:05 PM
sniper27's Avatar
sniper27
Thanks...definitely going to get some goo gone, as there are still some plasti dip residue left on the grill. that stuff is a pita to get off towards the back. I guess I just didn't do a good enough job the first time. It doesn't look all that bad, just some uneven spots and i'm picky, so off it goes. I might try again this weekend.
Old May 19, 2011 | 08:41 AM
Fezzik's Avatar
Fezzik
Yeah. wheni painted my grill i was about 6 inches away and put it alittle heavy.
GFTW
Sep 19, 2015 03:52 PM
gdaelemans
Sep 15, 2015 12:20 PM
nbast
Sep 14, 2015 12:39 PM
Detailed Image
Lighting/Cleaning Products
Sep 14, 2015 07:24 AM
gdaelemans
Sep 13, 2015 09:36 PM
