One headlight turns off and stays off
happens to me on my 09 g37 coupe. I have the projector lights with iron man leds. The projector light on my driver side will randomly go off and stay off then after a while it will go back to normal. I bought a new ballast cause my mechanic told me that's what it was but everytime I go to install it the light starts working again. I got a ballast for like 80 bucks on amazon btw. 500 is ridiculous
I think i have the normal lights the car came with! but i asked my mechanic if i should go to Infiniti since i have a good friendship with the service manager because i have bought in multiple cars from them and he said it will cost me like 1000$ screw that! and yes i have seen them on Amazon or eBay for 50-100$! did you install it yourself or did you go to a shop?
update. shop installed new ballast and light works perfectly. lets hope it stays like that tho
I know this is an old thread but...
I only have had my g37x sedan for a month now and need to replace on me if my ballasts. I been searching online and these forums and can’t find a DIY ballast replacement. Is there any way a kind person can just direct me to it. Thank you in advance!
I dont have a link handy, but the quick and short of it is, you need to remove your front bumper to get to the headlight, then remove light. The ballast is a metal box located on the bottom of the headlight housing. There are two versions of the ballast I know of. Both will work fine. Simply unplug, and unscrew ballast, and replace with new one.
Headlight goes out...not a bulb issue
I have a 2009 G37S Sedan and I am having the same issue(s). I have replaced both bulbs and one ballast. It started on the right and then the left. The headlight will act like it wants to come on when I start my car, but then one side goes out. I turn my steering wheel switch back and forth and the light comes back on. I have had a headlight to stop working while driving. I replaced both lights and the left ballast and still have the issue. I have taken it to a local mechanic and they can't determine the issue.
Skyline_G35 (08-25-2022)
#29
Lee Nguyen
02-20-2020 05:05 AM
AzNBoY92
05-09-2014 11:06 PM
