Wind noise from passenger window
Old Jun 23, 2015 | 06:01 PM
  #46
akiradavis's Avatar
akiradavis
bringing this back from the dead
Before, I was getting the noise only from the driver side window, but I thought that was due to the tints. Removed the tints, noise was quieter but still there. Figured it was due to the body shop screwing up the alignment but it was around the time when a family member died so I couldnt deal with it. Forgot about it, just turned up the music.
Fast forward to recent, my passenger side window is bashed in one morning my some scumbag. They didnt take anything but the window had to be replaced. I replace it using an emergency glass shop. It was horribly aligned so bad that I couldnt talk with the windows up! Brought it back to the shop and it took them 3 more tries (kept coming back) for them to get it where its at now. But its not perfect by a longshot. Now both sides have wind noise.
I may just replace the seals and ask the stealership to align the windows properly. Just a heads up for people who have this issue. Window reset doesnt do much and it has to do with how glass is aligned on the track. If you take a look at the glass while in the door, you will see it is almost floating on track. It's a bitch to align it on both a X, Y AND Z axis, but thats how it goes (from the untrained eye). Anyhow, this is my 2 cents. If your G gets broken into, you may run into this issue after fixing the window.
Old Jun 23, 2015 | 06:15 PM
  #47
jman09's Avatar
jman09
how/why would tints cause this???
Old Jun 23, 2015 | 06:55 PM
  #48
AzNBoY92's Avatar
AzNBoY92
Poorly made. My passenger side one is torn and wind noise is coming in badly. The problem is when the window goes up it doesn't go up into the seal but actually goes past it and so since its not sealed in correctly noise comes in. Wonder how much to replace.
Old Jun 23, 2015 | 07:59 PM
  #49
amciner28's Avatar
amciner28
I feel like people keep talking about tints and windows for this... but I'm not sure why. Stop me if someones said this already but I have the same issue on the passenger's side (doesn't start making noise until 80-90 MPH) but to me it must be the side view mirror that the noise is coming from.
To make sure I'm talking about the same sound as everybody else: it's a high pitched whistling.
Old Jun 24, 2015 | 03:10 PM
  #50
SpeedBallDEVIL's Avatar
SpeedBallDEVIL
My 2011 coupe had the same issue, however it was coming in from the rear of the window near where the seatbelt rests. My driver side was so badly worn that you could see into the car if you looked at the right angle.
I brought the car to infiniti and had both driver and passenger seals replaced under warranty. Even got a free rental for the day under warranty.
Old Nov 22, 2015 | 04:02 PM
  #51
acousticapertur's Avatar
acousticapertur
How long did they take to replace the seals? I've been chasing the high speed air leaks in both windows of my car for almost a year now - this is insane. Been to the dealer for it 4x, and I'm ready to go in a 5th.
Passenger side they found the window regulator was broken plus the window was out of alignment, and driver side my window was out of alignment as well. The driver side they fixed the leak in the front but created a leak in the back top corner. Passenger side was drastically reduced from the vacuum cleaner sound, and is now also an air leak relegated to the rear top corner.
I'm wondering if my weather seals are out of shape - can anyone show me a properly sealed window seal at the back top corner?
It's infuriating going to the dealer and they claim they can't hear anything - everyone who's been in my car, including my hard of hearing Dad, can hear it, but of course the dealership "can't hear anything."
Old Jan 18, 2016 | 02:08 AM
  #52
Nxf0's Avatar
Nxf0
Got wind noise & no warranty
Hey guys ,
So I just purchased 2011 g37xs coupe with 31k mile and just came to know that I have this crazy wind noise . (Both side , passenger side gets insanely annoying at speed 60+ ) took the car back to dealer where is purchased the car (not Infiniti , it's an Acura dealership) and they told me that they cannot help me. I don't think they like me that much since I didn't buy the 3rd party extended warranty from them
Anyways .. Anybody was able to get this fixed at local body shop ? How about Infiniti dealer , anyone knows how much they will charge me to fix this ? By the way I checked everywhere and I cannot see any torn on window seal ... Not sure if I was looking at the right place though .. Tried the window reset technique as well and that didn't help either :/ any tip , will be greatly appreciated!
Old Jan 18, 2016 | 12:59 PM
  #53
isosunrise's Avatar
isosunrise
I have the same problem. 2 dealers have replaced the window moldings and nothings helped.. Brought to a local body shop and they say the door alignment is off. When I push the door in with my body the seal becomes much tighter. Unbelievable the dealer I purchased from (englewood infiniti) wont help.
Old Jan 25, 2016 | 12:15 PM
  #54
scaperd's Avatar
scaperd
Wanted to chime in on this thread. I have been chasing the wind noise for awhile and wanted to pass on some updated wisdom for future readers.
Part 1: If your car was in a wreck(regardless if carfax says it was) your door alignment wont be factory perfect and you get the horrid wind noise from around the sides or corners of the window. To fix this you need to have the door realigned and then the window has to be aligned. Yes this is a two part alignment. Your window can be aligned by two screws hidden under your door panel, the screws adjust how high the glass sits in the front and rear of the window. This goes without saying but do this after the door is set properly.
Part 2. As are cars are aging I've had both my rubber seals along the top of the mirror crack like in previous posts. This part as of January 2016 is 45 dollars from your dealership and takes about an hour to DIY it in place. You take the door panel off, then the mirror off and replace it. No more wind noise, or at least a massive reduction lol.
Hope this helps future drivers.
FYI I have an 08 G coupe, accident free.
Old Jan 25, 2016 | 02:39 PM
  #55
spinna001's Avatar
spinna001
whats the part number?
Old Jan 26, 2016 | 01:49 AM
  #56
quakerroatmeal's Avatar
quakerroatmeal
Definitely interested in the part number as well.
Old Jan 26, 2016 | 12:08 PM
  #57
scaperd's Avatar
scaperd
I still have the driver side seal in the bag(Its cold as hell in Ohio and I'm procrastinating lol), Ill take a picture and upload it tonight of the seal and part label.
Old Jan 26, 2016 | 05:23 PM
  #58
quakerroatmeal
So you replaced both sides for 45$?
Old Jan 26, 2016 | 09:19 PM
  #59
scaperd's Avatar
scaperd
fuzzed
Aug 21, 2020 09:35 AM
SpeedBallDEVIL
Oct 2, 2015 11:20 PM
RexHavoc
Oct 2, 2015 11:47 AM
si_driver
Oct 1, 2015 09:53 AM
stm37s
The M - Spot
Oct 1, 2015 06:53 AM
