Driver Window Power Issues
Old Nov 16, 2009 | 08:38 PM
08G37S's Avatar
08G37S
Today, when I went to turn off my car, the driver window would open automatically upon turning off the car. The window also can not be rolled back up unless the driver door is closed door is closed. When I get out and open my passenger door, the passenger window rolls half way down. My trip mileage, presets, every custom setting was blanked.
What happened???
Anyone know a fix? Thanks!
Old Nov 16, 2009 | 08:51 PM
08G37S's Avatar
08G37S
OK - Now the horn and alarm horn are going off by themselves. I yanked the fuses so the noise would go away.
Also, the Auto-Up/Down function doesn't work. You have to hold the switch down.
This is awesome!
Old Nov 16, 2009 | 08:57 PM
BOXER83's Avatar
BOXER83
You should take it to the dealer.
Old Nov 16, 2009 | 09:01 PM
08G37S's Avatar
08G37S
I am in Lubbock, so no near Infiniti dealer. The Nissan dealer won't even do an oil change for me. Kinda stuck other than Infiniti Roadside - which is like dealing with Dell Tech Support.
Old Nov 16, 2009 | 09:06 PM
08G37S's Avatar
08G37S
I am starting to think that cold weather and an underlying electrical issue are the culprit.
https://www.myg37.com/forums/g37-cou...to-grubbs.html
February 2009 I had this mess, and it started in October/November before the 6 times of being towed to Infiniti.
Wonder how I can present the issues to them where they will actually fix it.
Old Nov 16, 2009 | 09:08 PM
Weiboy718's Avatar
Weiboy718
wow, wondering what's causing it
Old Nov 16, 2009 | 09:10 PM
Disconnect your negative battery cable for 15 minutes. Then reconnect it and perform the window reset procedure outlined in your owners manual. That may fixi it.
Old Nov 16, 2009 | 09:24 PM
ucla bruin's Avatar
ucla bruin
^+1, he beat me to it. Some disconnect it for overnight.
__________________
Old Nov 17, 2009 | 12:07 AM
08G37S's Avatar
08G37S
Will try that - thanks for the info!
Old Nov 17, 2009 | 01:24 PM
BOXER83's Avatar
BOXER83
When you have gone to the dealer did the tech come out so that you could show him what it was doing? If not then if you have to take it back tell them you would like to see if the tech can come out. The dealership I went to sent a tecj out to ride with me to check everything out (different issue than you were having).
Old Nov 17, 2009 | 05:33 PM
08G37S's Avatar
08G37S
Yea I had a tech ride with me. But only some of the symptoms could duplicate so not everything was fixed. The temp was different at DFW than Lubbock so it wasn't really a fair comparison. But they don't care.
Old Nov 17, 2009 | 06:04 PM
BOXER83's Avatar
BOXER83
Have you tried a different dealership? I think you should show a little more aggresion and see what happens.
Old Nov 17, 2009 | 09:40 PM
08G37S's Avatar
08G37S
No, but thought about the El Paso or OK City dealers instead. It just sucks since the car is towed there and I'm not there in person. They kinda string you along and complaining over the phone doesn't make the scene it does in person. Just gonna get it to work till Christmas break when I got more time off of school/lab.
Old Nov 17, 2009 | 09:49 PM
BOXER83's Avatar
BOXER83
Well I hope everything works out. Good luck
Lt8Che
91
Apr 8, 2022 04:55 PM
Thedbarz
33
Feb 9, 2016 12:05 AM
Digilog
Aug 17, 2015 03:54 PM
350zrunnin12s
Aug 9, 2015 09:55 PM
