Reverse Lights!
Old Sep 2, 2009 | 05:38 PM
oXMav3ricKXo's Avatar
oXMav3ricKXo
Reverse Lights!
I have a 09 G37S coupe and i wanna change the reverse lights to L.E.D.S but i just wanna make sure im doing it right, so those anyone know how to access them? i tried searching and couldn't find anything. Thank You in advnace!
Old Sep 2, 2009 | 05:50 PM
jnguyen's Avatar
jnguyen
They have 3 push pin on each side on the inside. use a flathead to pop those off. Pull the rug back and you have access to 3 bolts. They should be a 8mm or a 10mm. unscrew those 3 then get a hammer or mallet and bang on the end of the screws. it should pop the tailight right out.
If you have problems then I will make a DIY for you. Doesn't take long and it should be easy
Old Sep 3, 2009 | 12:10 PM
lakers8's Avatar
lakers8
Make sure you get high powered LED's or else you will not be seeing any noticeable light output when in reverse.
Old Sep 21, 2010 | 02:31 AM
CtK's Avatar
CtK
Just tried to install these 921 LED for my reverse lights and they dont fit!!
Did i buy the wrong one??
please help
Old Sep 21, 2010 | 11:06 AM
2008G-Man's Avatar
2008G-Man
See the LED's I used, nice and bright and the DYI is pretty easy. There are several out there, just search. I would use the "Pull Hard" method and not the "Tap with a hammer" method though. You don't want to crack the plastic that encases the bolts.
https://www.myg37.com/forums/body-in...-used-fyi.html
2008G-Man's Avatar
2008G-Man
please help
Yes you did ... there are tons of posts on the subject.
Old Apr 7, 2011 | 01:36 PM
STOOF's Avatar
STOOF
wtf.....
Old Apr 7, 2011 | 01:43 PM
breftayka's Avatar
breftayka
^^^^ That video is FAIL! :P
Old Apr 7, 2011 | 02:32 PM
CDONNS's Avatar
CDONNS
....im so confused right now?
Old Apr 7, 2011 | 02:55 PM
Wezbian's Avatar
Wezbian
Wheres the posts on this issue? Do i need to "search"
User 122320
Jun 12, 2017 01:28 PM
timc00k
Sep 25, 2015 12:35 PM
claudiohv
Sep 17, 2015 01:43 AM
B Feelgood
Sep 13, 2015 05:56 PM
