Moonroof Tilt Problem
Old Mar 22, 2008 | 02:45 PM
Sweeet P's Avatar
Sweeet P
I've recently noticed that when I "tilt" the moonroof...there is sort of a...I don't know how to explain..."grrrrt" sound. I happened to catch it as I was taking it for my first oil change. Dealer said because I don't use it the moonroof often...it gets stuck. Thus, the motor sort of struggles to "tilt". He was convinced that I need to use the tilt feature often to keep it from happening again.
Well...it's there again...each and every time I tilt. Note that there are no unusual sounds when fully opening/closing the moonroof or tilting it down......only on the way up.
Anyone else had this problem? Appreciate any feedback.
Old Mar 22, 2008 | 05:35 PM
DiamondGCoupe's Avatar
DiamondGCoupe
Yeh it needs some lube!
Old Mar 22, 2008 | 05:37 PM
Pms1212's Avatar
Pms1212
No, I haven't had any problems so far, and I use the moon roof. All I hear is the sound of it going up but no grrrrt sound.
Old Mar 22, 2008 | 05:51 PM
SPOHN's Avatar
SPOHN
From Z to G
+1 Needs it somewhere. I tell you, the things dealers will say.
Old Mar 22, 2008 | 06:41 PM
bboysteele's Avatar
bboysteele
It is all about the Lube.
Old Mar 22, 2008 | 08:35 PM
DiamondGCoupe
Lube or lewd??!!
Hahaha I love Reno 911
Old Mar 24, 2008 | 03:01 PM
Falcon124's Avatar
Falcon124
A brand new moon roof shouldn't need lube. Pretty **** poor answer by the dealership if you ask me. Since you say you first noticed this when you were on your way to get your first oil change, I'm assuming your car still "smells" like a new car. I don't think it should be sticking either on a new car. Maybe after 6 mos of no use, the rubber gasket between the glass and the surrounding frame might stick a little but not enough to bind the motor. I'd keep an eye on that and don't hesitate to get the dealer to fix it. Remember, "the squeaky wheel gets the grease".
Old Mar 24, 2008 | 03:03 PM
Ahujadaddy's Avatar
Ahujadaddy
i had this too, and noticed it as i drove off from the lot right after purchase... it went away by my second oil change, 3750 miles. Keep an eye on it.
Old Mar 24, 2008 | 03:26 PM
KAHBOOM's Avatar
KAHBOOM
Super Moderator of Pwnage
I haven't had any noises like that from mine yet. But on my previous generation G there was a small insignificant grunt on the way up when tilting.
Old Mar 24, 2008 | 03:35 PM
Sweeet P's Avatar
Sweeet P
Thanks for the feeback. Still make the sound. I'll probably wait a bit and give it a couple more weeks. It's not a big deal but I agree....a new car with 3800 miles shouldn't have that kind of problem.
Old Mar 24, 2008 | 03:41 PM
t-bone1924's Avatar
t-bone1924
Mine had the same grrrrrr noise on tilting. Had the dealer lube it...no more problem since.
Old Mar 25, 2008 | 01:51 AM
shumby's Avatar
shumby
NO issues here and my car sits for a month at a time with out use. I would definatly go get the dealer to look at it.
(Oh sorry i got flamed by the admin last time i mad e a post like this. Said it was a waste of a post. I guess there were only to good posts on here eh O NO?)
butwhatuptho
Oct 4, 2015 07:51 PM
Msherburneg37xs
Intake and Exhaust
Sep 30, 2015 06:39 PM
MrRiv
Sep 29, 2015 04:59 PM
k19g37x
Sep 29, 2015 02:46 PM
