Installed Android Auto
Old Mar 14, 2019 | 04:04 PM
BeeW's Avatar
BeeW
Originally Posted by Conboss
gotcha. The main reason why I asked about CarPlay is because I use an iPhone, and don’t know a whole lot about these types of systems. I guess what I could do is load just standard android on it, and connect it to my wifi somehow in my house and load music on it. The main challenge would be the touch screen at this point.
Not sure how screen casting works on iPhone... But in theory, you could setup an RP3 to recieve screencasts over is own wifi network and just cast carplay to the screen. Then again, not sure if Apple supports simultaneous wifi+mobile data use. If not youd have a offline phone.
Edit: just learned about CarPlay dongles... Just pop one of those onto the RP3 running android, and it does exactly what I described above.
Old Mar 14, 2019 | 07:05 PM
icecube45's Avatar
icecube45
Originally Posted by inkognito
What's your approx cost of project?
Totally missed this earlier - I've spent probably about 200 on this project, but I also killed a pi and eliminated half the converters I needed.. So this could probably be brought down to around 150? 125? - Once I actually have time / motivation to make a serious write up I'll have a better idea.
Old Aug 26, 2019 | 12:59 PM
Conboss's Avatar
Conboss
Coming back to revisit this cause I have my own solution! (Untested as of now)
A while back my parents bought a little android box, but stopped using it because it was unstable. I'm currently trying to make the machine stable, and load vanilla android onto it. No, this doesn't fix my carplay issue yet, however that should be a breeze. My focus switched as I got an OBD2 reader, and would rather have the info displayed on the dash rather than on my phone. Reason being is my phone is heavy and it's big and blocks the buttons, and it'll kill my battery if I forget to plug it in, and when I get in I want it to just work!
If/when i can get this installed and tested, I'll write something up!
Old Sep 7, 2019 | 09:47 PM
icecube45's Avatar
icecube45
Also revisiting this to update with my progress - I've made a PCBA pi hat for the RGBS output of the pi, cleans up the wiring nicely and makes it much more reliable.
Old Sep 8, 2019 | 03:52 AM
MrBarley's Avatar
MrBarley
Was actually looking at this thread yesterday, how hard was it to do all this? Do you run the Pi in the glove box?
Been trying to find a simple solid solution to the lack of AUX/BT audio on my car.
Old Sep 8, 2019 | 04:00 AM
icecube45's Avatar
icecube45
Yea I run it out of the glove box (not sure it would fit behind the dash)
It was hard to develop, but I'm not sure how hard it would be to implement. It boils down to cutting some wires and running some new wires. Depends on your level of comfort with car electronics I suppose.
Old Sep 9, 2019 | 03:49 PM
Matthew Reimer's Avatar
Matthew Reimer
You can make some money selling this as a kit. I'm interested either in a what to buy and do or a kit with instructions to buy. Would really breathe some new life into this car.
Old Sep 10, 2019 | 01:45 PM
icecube45's Avatar
icecube45
If I wasn't always lacking in free time I'd entertain the idea..
I've detailed a decent amount of what needs to happen to make this work, but I'd be happy to answer questions/share my schematic
Old Sep 11, 2019 | 03:12 AM
MrBarley's Avatar
MrBarley
Honestly, if you're able to find time to write up a DIY with pics, that'd be awesome.
Old Sep 11, 2019 | 04:30 PM
icecube45's Avatar
icecube45
I'll see what I can do, but likely the best I'd be able to offer is a detailed schematic - I'm about to be carless for 4 or so months.
Old Sep 12, 2019 | 05:30 PM
Matthew Reimer
In your adventure into this. Did you happen to located the video signal wires to the factory screen? I have an idea for something but need that info.
Old Sep 14, 2019 | 02:26 PM
Surfnazi's Avatar
Surfnazi
They make a hdmi to rca converter
Old Sep 24, 2019 | 10:10 AM
Matthew Reimer
I mean the factory video signals from the brain to the factory screen.
Old Oct 28, 2019 | 03:37 PM
  #29
Conboss's Avatar
Conboss
I found an article from 95, a VGA to RGB Sync diagram. I’ll be heading to my electronics store tonight to see if I can pick up some gates, a clean piece of PCB and a couple other odds and ends to try and get the ball rolling... FINALLY!!
dopey
Dec 8, 2013 01:46 PM
Greggski
Feb 20, 2010 03:16 AM
EnviedG35
Dec 13, 2009 05:39 PM
