Help Amp Install Options
Amp Install Options
I recently purchased a 2012 G37 and one of the first things I got done was adding my amp and subs. I took it to a large chain store and told them to splice my RCAs and tap them into 23-26 based on the searching I have done here.
Well, when I picked up my car, they said they added a passive LOC after the Bose amp SMH. They told me that the 23-26 wires were only supplying .5v which they said was not good enough.
Needless to say the bass is very muddled. I contacted the shop and explained the bass being produced is not to my liking. They recommended an LC2i stating that it will fix the bass curve that the Bose amp messed with. AudioControl LC2i Line Output Converter
I did not like this idea as the Bose amp will process the signal and then LC2i will process it again. I think less processing the better. Since the only "problem" was the wires I wanted to use were only .5v, I asked them if I should use this product which would boost the voltage to the 4v (my amps max input voltage): AudioControl Overdrive Plus
The shop still recommended the LC2i.
So I am asking the G community..... It looks like I have 4 options and wanted to get a feel for which option you all would choose.
1. Keep it as is (passive LOC) - Muddled bass, not what I want.
2. Have them wire it the way I initially requested - Will probably have to turn the gains on my amp way up since the source is only .5v
3. Install the LC2i - This has good reviews but worried about the signal getting processed too much.
4. Install the Overdrive Plus - This would increase the pre-amp voltage so that I can turn down the gains on the amp which I would assume would reduce noise going to the speakers.
What would you do? Thanks in advance!
When I was doing my amp/sub install, I was initially going to go with the LOC, but many members here recommended to ditch the LOC because it muffles the bass. Instead, tap straight into 23-26. So I did what was recommended and I haven't had any problems.
Get it installed the way you initially requested and see if there's any problems. Don't buy all those additional items when you can get things to work without them. If there's any problems, then you can figure it out from there, but I don't think you will have any since me and many others are tapped into 23-26 without issues.
Ditch the LOC---run direct. Check my Build Thread for more detailed info. (https://www.myg37.com/forums/build-t...ml#post4052591)
Thank you for the responses. The installer insists the LOC LC2i (connected after the Bose amp) is the best way to go, but I will have them check the front wires (pre-Bose amp) to see if they are better than the rear and have them tap into either F or R pre-amp wires..... Despite what they say
It is now installed the way I wanted... but there is engine noise.
With regular twisted pair RCAs chopped off at one end and soldered, the noise was deafening. Went with a JL audio RCA cable meant for splicing and it cut the noise A LOT, but it is still there and it is sometime VERY high pitched.... uggg
Also, we added a ground loop isolator and it killed the audio signal.
Tim134219
08-17-2017 08:53 AM
flyingnimbus
10-03-2015 12:12 AM
weetodid09
01-04-2010 10:31 AM
