Help Base audio amp install
Old Jan 21, 2016 | 01:16 PM
m3clubracer's Avatar
m3clubracer
2010 Sedan Base audio with camera.
I am looking to install an amp with only RCA jacks for inputs. Apparently I need some sport of converter from speaker level to RCA.
Q: Is there a good and reliable one on the cheap that any of you have used?
I am not electrically inclined at all and I have RTFM but I can not determine which harness and wire to use wire taps to get the signal from the front speakers.
Q: Which harness and wires would I tap into for the front speakers to convert into RCAs?
TIA
Old Jan 24, 2016 | 07:26 PM
g37tx's Avatar
g37tx
^in the same boat as you. I tapped i to rear door speakers the blue and pink wire. But my loc still doesnt get signal.
Old Jan 25, 2016 | 07:32 AM
m3clubracer
Well lets hope someone rescues us...
Old Jan 25, 2016 | 02:26 PM
krazyfiend's Avatar
krazyfiend
Hoping the best for you guys, I had a Q40 sedan loaner a month or so back with base audio... I know the Bose is not anywhere near what people expect from a premium sound package, but it makes the base audio package sound like AM radio in comparison. I went back in the dealer after getting my loaner and asked if there was an issue with the audio and why it sounded so flat, muted, and like what I'd expect a Chevy Aveo rental car to have. I realized my oversight when I peeked back in the car along with the service adviser and noticed the lack of Bose. On a better note, I thoroughly enjoyed the awd Q40 X model attributes, but was so happy to get back in the comforts of my own car.
Yikes base audio people...that's some crap you're enduring when listening to anything in car.
Old Jan 25, 2016 | 03:02 PM
m3clubracer
G thanks! HAHA!
Old Jan 26, 2016 | 09:08 AM
m3clubracer
I think I have figured out the audio signal question.
In the attached pic I will use terminals 2-5 or 11-14 for the signal.
Q: Which terminal should I use for the power on signal for the amp? Someone please help?!?
File Type: pdf
Old Jan 26, 2016 | 12:53 PM
Landshark's Avatar
Landshark
Is base powered by the head unit, or seperate amp? Use front right and left (+ & -).
Use ACC for remote turn on, assuming it kicks out enough juice. Check to see its putting out 12V when car key is in ACC position. Some factory ACC wires only put out 12V when the radio is on for a power antenna.
Old Jan 26, 2016 | 12:55 PM
m3clubracer
No other amp so base must be powered by head unit. Thanks!!
35Sport
Dec 3, 2019 05:30 AM
Lego_Maniac
Jan 19, 2016 06:41 PM
sniper27
Dec 7, 2010 07:31 PM
