iPhone 6
Old May 2, 2015 | 01:01 PM
HB4LTHR's Avatar
HB4LTHR
iPhone 6
I have a 2008 G37S without navigation. The car came with an ipod cable. I recently bought an iPhone 6 and was told that if I get an 8 pin lighting adapter, I can plug it into the end of the iPod cable and the other end to the iPhone 6 and I will be able to play music through the system. Well I did that and it doesn't work. Does anyone have any idea why and is there something else I need to do like make an adjustment on the settings portion of the phone?
Thanks
Old May 2, 2015 | 01:56 PM
telcoman's Avatar
telcoman
Thanks
Use this
Lightning to USB Cable (1 m) - Apple Store (U.S.)
Telcoman
Old May 2, 2015 | 02:21 PM
HB4LTHR's Avatar
HB4LTHR
Thanks but there is no USB port on the car or the iPhone
Old May 4, 2015 | 11:46 AM
HB4LTHR's Avatar
HB4LTHR
Does anyone else have any suggestions?
Old May 4, 2015 | 11:57 AM
Rybitron's Avatar
Rybitron
If the adapter didnt work, your only option may be bluetooth.
Old May 4, 2015 | 07:07 PM
HB4LTHR's Avatar
HB4LTHR
How would that work?
Old May 5, 2015 | 10:06 AM
TheGspot37s's Avatar
TheGspot37s
What you need is the lightning to 30-pin adapter. I have an 08 G37s coupe w/out nav as well and it works.
Lightning to 30-pin Adapter - Apple Store (U.S.)
Old May 5, 2015 | 10:08 AM
TheGspot37s
You can't use the bluetooth for audio on the non-nav models, only phone use.
Old May 5, 2015 | 11:30 AM
HB4LTHR's Avatar
HB4LTHR
This is the part that I bought but it was from Amazon and didn't work. Again I am only interested in planning music through the car. Maybe I should buy the adapter direct from Apple?
Old May 5, 2015 | 12:37 PM
TheGspot37s
Perhaps you got a defective unit because I bought the Apple one and it works perfectly. Sometimes you have to change the mode to Aux and cycle back to the iPod/iPhone for it to register. Try that and see if it helps, if not then get an Apple one.
Old May 5, 2015 | 02:28 PM
HB4LTHR's Avatar
HB4LTHR
Thanks Gspot. I don't believe they are defective as the ones I bought had 2 in them. I tried what you suggested and they both don't work so I will return and go to my local Apple store and buy the genuine product. Thanks for your help.
delfinparis
Oct 8, 2015 06:06 PM
Awgd8
Sep 30, 2015 06:22 PM
bluej20
Sep 29, 2015 03:57 PM
sharmelan
Sep 23, 2015 11:48 AM
steven92
Sep 23, 2015 08:48 AM
