dash mounted USB charging port & voltmeter
Old May 21, 2015 | 06:40 PM
JSolo's Avatar
JSolo
Just say no!!!!!
^^Hands definitely work!
I'm hesitant messing with any dash panels that use clips. Typically end up breaking something.
On a scale of 1-10, this was probably a 2 to install. I'm not a fan of crimping so used solder and heat shrink tubing for the connections.
I did run into a bizarre issue. The stock 3 switch holder is keyed. The switches will only go in one way (one edge has a narrow width, other has wide, forget which one is where.) Had to mount mine upside do for it to fit the switch holder. It was either that or use a dremel to remove the guides from the narrow side. I didn't care enough to bother.
You can see in the pics below.
There's no way to rotate the switch in the plastic housing, it's all molded together.
The sonar switch got installed in the bottom piece but left it unplugged. The stock harness was so nicely wrapped and taped, didn't want to disturb it too much (odd wire noises?). In the last 3 1/2 years i've used the sonar switch exactly 0 times, leaving it always on.
Old May 21, 2015 | 06:49 PM
donshou's Avatar
donshou
It makes sense if you want the voltmeter. However, I use a car charger that fits in the cubby. The door can still close since its slim. It is a dual usb port that can push 2.4A per port.
Old May 21, 2015 | 07:02 PM
JSolo's Avatar
JSolo
Just say no!!!!!
I saw that one too, considered it, but like the OP, didn't like the rubber covers. I'm just glad to have a bit less cable clutter now. Just ordered some 18" micro usb cables on ebay.
Item # 121100495210. They come in a set of 5. Figure i'll lose a few over time.
delfinparis
Nov 16, 2015 02:26 PM
Awgd8
Sep 30, 2015 06:22 PM
si_driver
Sep 30, 2015 11:46 AM
mikysee
Sep 28, 2015 11:18 AM
Murkr
Sep 28, 2015 10:45 AM
