Adding OEM touch screen to Non-nav G37 '08
Old Apr 6, 2014 | 12:32 AM
ramirbass's Avatar
ramirbass
Smile Adding OEM touch screen to Non-nav G37 '08
I want to replace my current display and add a OEM touch screen display. Will it work with the current head unit or Do I have to get a nav unit as well?
Any suggestions will be greatly appreciated.
Old Apr 6, 2014 | 12:55 AM
quakerroatmeal's Avatar
quakerroatmeal
A little quick search and I found...
Originally Posted by jbregar
So, to do this what parts do you need? I assume the following:
- Nav head unit
- Nav faceplate
- Nav control panel
- Nav screen (since the non-Nav isn't a touchscreen, right?)
- Nav wiring harness
That about right?
Originally Posted by Corey Kunak
yes thats what you need if your going the splicing route (cutting into dash harness)
or if your doing to do it the way i did
old radio for connectors
wire
butt connectors
shrink wrap
soldering iron
Nav head unit
Nav faceplate
Nav control panel
Nav screen
Nav wiring harness
you'll also need GPS antenna for Nav to work
If you want to do 2010+ navi swap which includes a higher resolution hd screen you'll need the new harness that includes the new display connector.
Old Apr 6, 2014 | 01:03 AM
ramirbass's Avatar
ramirbass
Thanks for the reply. I only want to add the touch screen display for now if it is works without a nav unit.
Old Apr 6, 2014 | 04:32 AM
quakerroatmeal
Why would you need the touch screen if you aren't going to do the navi swap?
Old Apr 11, 2014 | 10:43 AM
magnum_rg's Avatar
magnum_rg
I also want to replace it, a main reason not a navigation, just to mirror my android device with Kivic One connector.
Old Jul 21, 2014 | 12:23 PM
skobenland's Avatar
skobenland
In terms of the wiring harness and going from a non-nav head unit to a nav head unit, what all needs to be purchased? ('08 G37S w/o nav).
Old Mar 9, 2016 | 12:52 PM
Chris0831's Avatar
Chris0831
Non navigation
I want to upgrade my non navigation g37 to navigation my question is this. Is they sell the. Adapted cable Or I need to change my Dash harness
Old Sep 29, 2023 | 12:28 AM
Wooshh's Avatar
Wooshh
I’m wondering the same thing. Can I install OEM Nav Screen to replace non Nav and have a touch screen for a carplay module like VLines?
Old Sep 29, 2023 | 08:47 AM
ILM-NC G37S's Avatar
ILM-NC G37S
No. The OEM NAV screen will not work in non-NAV cars. The systems can not be "mixed-and-matched,"
WolfSongX
Car Care & Detailing
May 10, 2017 07:26 PM
joeposter
Sep 8, 2015 04:36 PM
KAHBOOM
Aug 25, 2015 11:05 AM
GW330
Aug 12, 2015 12:19 AM
RoyalG37
Aug 11, 2015 12:21 PM
