Remote starter installed!
I'm thinking of buying EVO-NIST (Amazon.com: Fortin - EVO-NIST1 - Stand-Alone Remote Starter System For Nissan Infiniti With Push-To-Start Smart Key: Electronics) which comes prewired for Nissan and Infiniti with push start button. How hard will it be to install? I've hard wired radar detector and replaced start button with GTR button so I'd like to think that I'm handy but this seems like a serious undertaking...this is for wife's automatic sedan.
Also, do I need to buy flash-link firmware update with EVO-NIST?
What did everyone do with all the extra wires that don't get hooked up? Did you just cut them really short?
The t harness has a lot of spare wires and last time I left them alone but i wanted to try and do a cleaner Install this time.
So you didn't run the one green wire with the metal pin on the end over to the passenger side and yours still starts?
I just tried installed the dballpro2 and all I'm having is issues. I'm able to program it fine. I hit lock x3 and i see the dball led blink green, my parking lights flash then the unit starts to blink orange and red. it repeats this about 3 times then it doesn't do anything. I tried re flashing it multiple times and still no luck. not sure what i am doing wrong.
last time with the dball2 everything plugged in an it started right up.
I used only the DBALL2Pro...This is the only module that still supports 3x remote start with factory remote..The same steps worked for me last night when I installed the same kit on my dads car, he has the same car as me lol...That install took me about 25 minutes.
What do you have? What type of car? Year? Are you using the config wizard that pops up? It should ask you to put your vehicle info...
couple things:
1) program module with the xloader on the site, using the config wizard..Make sure you select viper alarm, and uncheck security (that should be the first sceen)
Hit "next" and check the options to find virtual tach...Change IT to Virtual Tach, it should be under Tachometer.
2) make sure on the module you either; CUT the LOOP if you have a Automatic car. Or keep the LOOP if you have manual
3) If you successfully loaded the firmware, and you plugged everything up and the module is BLINKING! Then perform the reset on the module using the manual...I think it goes:
Unplug the White harness (power to the module). Hold down programming button, plug in the white harness...wait for several seconds until the lights solid, then release the button. The light should go off and come back on solid (if it didn't try it again, follow the manual)
Afterwards you should be able to program the key; 1) hit unlock, 2) place key fob in port, 3) hold down brakes for 5 seconds, or until green light 4) remove key fob 5) Test it out.
Good luck
Ya i can do a video tomorrow after work. it was getting too cold her in Ohio so i gave up for today.
I noticed it says there are two version of the T harness - what version did you guys get? Mine says THNISS3C (rev1).
I'm actually trying to figure out what remote start to go with and the dball2pro, I think, is my best option since it still supports the 3x lock start. What is the difference between the THNISS3 and the THINSS3c harness?
If you get the Dballpro you need the harness that goes with it THINSS3c
Make sure you cut the loop if your car is auto!
If your getting the response from the module to the cars computer Im not sure.
I know when i used the dball2 last year i had to connect 3 wires to the BCM and i see now its only showing 1 wire in the manual - is this because of a newer firmware for the dball2?
Ill do a hard reset on the dball and reprogram it and make a video later today.
Ok. I'm pretty confused now. I went on the "direct" website and it still says the regular dball is still RSR. I thought someone had mentioned that they weren't RSR with the 3x lock anymore. Am I reading this right? I want to get either one but I want to make sure I'm getting the right one. Can someone direct me in the right path please? I just want to be able to remote start my 2008 g35x with the 3x lock feature.
