Bluetooth streaming through USB On non-nav g37
Old Sep 10, 2013 | 07:30 PM
Zeuloo's Avatar
Zeuloo
Red face Bluetooth streaming through USB On non-nav g37
Hey everybody, this is my first post here and I'm hoping I can find an answer to my problem. I just purchased a 2012 infinity G37 with no auxiliary input and no navigation. The only sort of Input available is a USB port. I have an android and would like to stream Bluetooth audio. Does anyone know how I can do this? When I connect my phone through the USB it cannot read the device. I have a Samsung Galaxy S4. It seems like the only devices that the system can read are flash drives, iPods, and iPhones. I'm thinking that there must be a Bluetooth USB adapter that I can plug into the USB port to stream the audio, but I'm hesitant to purchase one because I'm thinking that the car will not recognize the Bluetooth USB adapter as a hard drive.
HELP!!!
Old Nov 20, 2013 | 10:33 PM
ross7778's Avatar
ross7778
I was wondering the same thing. I think USB bluetooth devices will only work with computers though.
Old Nov 21, 2013 | 08:47 AM
blazeplacid's Avatar
blazeplacid
USB to bluetooth devices dont work to well with our cars set up
you can pick up a 32gb USB stick for pretty cheap
a used 60/80gbipod classic is usually pretty cheap also. Ipods have a better screen display vs a USB stick.
I use both. I use the USB for new music I recently downloaded and the ipod for the rest of the collection
Old Nov 24, 2013 | 11:12 PM
joker44's Avatar
joker44
USB to BT don't work very good, but you can always make some bigger modification like I did. Try to connect to your headunit's xm audio input and use it as aux in. Then you can connect to it some BT receiver:
http://g37.pl/bt/
Old Dec 7, 2013 | 08:26 PM
ross7778's Avatar
ross7778
http://g37.pl/bt/
What is the mount you are using for your phone?
Old Dec 8, 2013 | 07:57 AM
joker44's Avatar
joker44
this one with the holder dedicated to lumia 920
http://brodit.se/product.html?id=854...edan&year=2011
Old Dec 8, 2013 | 03:36 PM
MrMefiniti's Avatar
MrMefiniti
Hi All... I am not sure but I think I have a good solution here. I posted this in the DIY section:
ATTENTION THOSE LOOKING FOR A (PROPER) AUX INPUT FOR YOUR 2012 INFINITI G37 WITHOUT NAV!!!
https://www.myg37.com/forums/d-i-y-in...-grom-box.html
I am not sure but there is a chance this will cover 2010-2013.
Hope this helps<!-- google_ad_section_end --><!-- google_ad_section_end -->
Old Jul 10, 2015 | 06:38 AM
wankelrx8's Avatar
wankelrx8
Android App
HELP!!!
I found a wireless solution for those with Android phones. There is an app in the playstore called Bluetooth Mono Router that lets you play audio and music through the phone bluetooth connection in your car. It's not stereo, but if you're just looking for a way to play audio and don't care if it's mono, then this app is for you.
Old Sep 30, 2018 | 01:17 AM
lektrix's Avatar
lektrix
Bump...... after all these years does anyone have a solution??
Old Sep 30, 2018 | 07:09 AM
ross7778's Avatar
ross7778
Yes.
USA SPEC BT45-INFI Bluetooth Phone, Music & AUX Input Kit for Select 2003-2012 Infiniti Nissan Models https://www.amazon.com/dp/B00XUPP4TY/ref=cm_sw_r_cp_api_Y6kSBb4Y8E44F
Lt8Che
91
Apr 8, 2022 04:55 PM
JoshB
Oct 15, 2015 03:08 PM
joeposter
Sep 8, 2015 04:36 PM
GW330
Aug 12, 2015 12:19 AM
