Help Bose 12V Remote Wire Not Sending 12V to Sub Amp
I'm bypassing the rear deck woofer (2009 G37x Sedan w/ Bose) to hook up my Rockford P5002 with Sub and having problems with the remote wire that previously turned on the Bose woofer amp. My DMM tests it at 12V, however, when I patch it into the remote port on my Rockford amp, it drops to 4.5V and does not turn the amp on.
The remote wire I am splicing is B43, wire 3.
Seen here: https://www.myg37.com/forums/audio-v...breakdown.html
Additionally, the RCA splitter I have feeding the Rockford from the Bose woofer output gives only a buzz when I plug it into the Rockford RCA ins (bridging REM to +Terminal for power on). When I test each RCA with headphones, they are getting a clear audio signal. Ground loop perhaps?
I've tried:
1. Two different ground points - ground is strong, and attached capacitor is charged.
2. Plugged iPod into RCAs on amp while bridging REM to +terminal. Amp powers on fine, and plays ipod fine. It just buzzes when I give it the RCA signal from the Bose woofer out (which I've verified is a clear signal when not plugged into the Rockford)
3. Tried using Remote wire 20 on B41 instead (main Bose amp remote/on from HU) and it loses enough voltage that both the Bose amp turns off and my Rockford fails to turn on.
It seems like A) I might have a ground loop with the RCA ins buzzing. and B) My Rockford's 12V Remote terminal could be pulling too much current which is causing a drop in voltage. Any other ideas? Any suggestions to remedy these things?
I've tried:
I've tried:
I've tried:
Pac-Audio.com Product Details | iPod Integration for your car and More by Pac-Audio - Connecting you to the future
mikysee
Sep 28, 2015 11:18 AM
dedmanchan
Sep 24, 2015 11:25 PM
