Bluetooth phone jail
Old Oct 30, 2012 | 10:36 PM
TexasGuy's Avatar
TexasGuy
On my 2010 coupe (w/o nav) paired to my Android OS Motorola cell, the moment that bluetooth connects phone to car, it dials and will not end the connection until I turn off bluetooth. Disconnect button on steering wheel won't work. Very annoying - just started this recently. Only solution I've found is not use bluetooth for phone. Searched this forum, didn't see a similiar problem. Any ideas on how to fix this? Appreciate your input.
Old Oct 30, 2012 | 11:26 PM
TVD's Avatar
TVD
A couple of things you might try:
1. Remove all recent calls and see if that helps
2. Temp. remove the offending #
3. Uninstall the Blue Tooth and the re-install.
This is what I would try. X Hacker
Old Oct 31, 2012 | 08:19 AM
TexasGuy's Avatar
TexasGuy
Thanks TVD - will try today.
Old Oct 31, 2012 | 11:19 AM
Josh's Avatar
Josh
curious.. are you running a stock rom or custom rom?
Old Oct 31, 2012 | 03:00 PM
TexasGuy's Avatar
TexasGuy
Working
TVD - thanks - re-installed phone & she works as before.
delfinparis
Nov 16, 2015 02:26 PM
delfinparis
Oct 8, 2015 06:06 PM
butwhatuptho
Oct 4, 2015 07:51 PM
parkern
Oct 1, 2015 10:15 PM
mikysee
Sep 28, 2015 11:18 AM
