Installing subwoofer + amp question
Old Mar 29, 2010 | 03:08 PM
jbrady3324's Avatar
jbrady3324
I am gearing up to install an IDQ10 sub and an amp. Are you guys running new wires from the HU to the amp or just replacing the wires from the amp to the sub?
Also, are you leaving the rear 6x9 woofer operational? I was wondering if that could be wired for mid-bass
This is for a sedan
Old Mar 29, 2010 | 03:41 PM
snaik69's Avatar
snaik69
check this thread out...for your question on wiring...
https://www.myg37.com/forums/audio-v...r-the-sub.html
Old Mar 29, 2010 | 10:24 PM
redfoster's Avatar
redfoster
Just replace the wires, don't run new ones. And leaving the 6x9s in for fill would be great, just put them on a cross-over if you don't have something else.
Old Mar 30, 2010 | 02:02 PM
jbrady3324's Avatar
jbrady3324
Does the sedan have 2 6x9s or 1?
Old Apr 7, 2010 | 09:50 PM
snaik69's Avatar
snaik69
sorry jbrady dont mean to hijack but i too would like to know what happens with the factory woofer. i too am just adding woofer and amp....and dont want to touch anything else. i dont know much about crossovers...can this be done on directly on the amp?
Old Apr 9, 2010 | 11:46 AM
snaik69's Avatar
snaik69
bump bump
Old Apr 9, 2010 | 02:49 PM
redfoster's Avatar
redfoster
Some amps have a built in cross-over you can tune. I don't know what speakers are in the sedan, but if you're just tapping off the input wires to the Bose amp from the HU then nothing changes from the factory setup. The only change is you've added a sub and amp to juice up the low end.
If you're amp doesn't have the cross-over built in you can pick one up at any car stereo shop, online etc. It just eliminates unwanted frequencies to/from your amp. So for a subwoofer you get a low-pass cross-over to eliminate high frequencies for a much cleaner sound (and it's easier on the sub).
If you're adding a sub, I might add a high pass filter (cross-over) to the 6x9's to remove some of the bass. The subwoofer is handling that now and the 6x9's will sound much better.
Old Apr 12, 2010 | 12:24 PM
snaik69's Avatar
snaik69
thanks Redfoster...very helpful.
GW330
Feb 2, 2024 05:41 PM
G's
Nov 5, 2023 12:01 PM
sLADe781
32
Nov 28, 2015 03:23 AM
blazeplacid
Sep 17, 2015 10:50 AM
