G37 Coupe Amp Power Wire
Old Feb 23, 2010 | 10:00 PM
JLai's Avatar
JLai
Originally Posted by iasskicker
The back cushion is giving me quite the pain still. Where did you grip it to pull up?
I have a feeling for the pins one on each side and I tugged extremely hard but it did not budge.
You only need to remove the seat cushion, not the back cushion. I sat down, hovered, and pulled straight up. Once one side is off, the other is a lot easier.
Here's a picture taken by Finagle to give you an idea of where the plug is:
Old Feb 25, 2010 | 11:48 AM
digitaldistorte's Avatar
digitaldistorte
Did you ground underneath the seat somewhere? I'm going to do an amp install someday..
Old Feb 25, 2010 | 11:49 AM
JLai's Avatar
JLai
I drilled a hole and ground in the trunk.
Old Feb 25, 2010 | 11:20 PM
Haji's Avatar
Haji
I got it thanks a bunch.
And for the ground, I've heard there is one bolt nearby when the carpet is exposed to reach the amp.
Old Feb 26, 2010 | 02:11 AM
digitaldistorte
Hmm...i was thinking self-tapping screw.
Old Feb 26, 2010 | 10:49 AM
JLai's Avatar
JLai
It would be the same thing. There's still a new hole made with a self-tapping screw and the ground will still be held down by a screw.
superjoey
31
Mar 22, 2023 11:56 PM
Lt8Che
91
Apr 8, 2022 04:55 PM
Thedbarz
33
Feb 9, 2016 12:05 AM
blazeplacid
Sep 17, 2015 10:50 AM
