XM changed to SIRIUS, IT WORKS !!!! G37S, no NAV
Old Jul 23, 2009 | 01:52 AM
boyah's Avatar
boyah
Originally Posted by HamstersG
I received mine today from Grubbs. To answer my earlier questions about new or refurb, I called Grubbs and they said it was new. The box was a sealed Nissan kit as OP described with everything needed to do an install in several different model cars.
I attached 4 pictures to help.
1) All removed. The box on top is the voice integration module.
2) With Nubs. This is the back of the Sirius unit. Look closely at the two nubs. This is what prevents the XM antenna attachment from slipping on.
3) With Nubs Cut Off. I took a razor knife and cut off the nubs. Now the XM antenna attachment will slid on and the locking clip will still work and keep it from coming loose.
4) Installed. Sirius unit installed and antenna connected.
Activated, set the channels. Works perfect and fully integrated.
do you have a coupe with navigation? It sounds like you are using the stock XM antenna to recieve the sirius signal? Please verify..
Chris Olson
Dec 29, 2025 07:59 PM
superjoey
31
Mar 22, 2023 11:56 PM
warpeacelove
Oct 28, 2015 02:59 AM
GW330
Aug 12, 2015 12:19 AM
