how to do ecu reset with batt disconnect
Old Sep 21, 2008 | 01:01 AM
sahiwal007's Avatar
sahiwal007
hey guys,
i have tryed doing the "pedal" ecu reset but it just wont work , i need some help doing the ecu reset by disconnecting the battery. how do i do it? is it easy? will i get shocked
thanks for the help
Old Sep 21, 2008 | 03:37 AM
bboysteele's Avatar
bboysteele
hmm....disconnect the battery and leave it disconnected overnight. You could disconnect it and then hold down the brake pedal and wait 15 to 30 minutes to do the same thing. Beyond simple and talked about before.
Old Sep 22, 2008 | 10:39 PM
sahiwal007's Avatar
sahiwal007
thanks for the info, so i just have to disconnect the negative side overnight right?
Old Sep 22, 2008 | 10:40 PM
amoney805's Avatar
amoney805
Yes.
Old Sep 22, 2008 | 10:54 PM
DiamondGCoupe's Avatar
DiamondGCoupe
Either side, 15 minutes is sufficient but easier to leave it overnight. Just fyi incase it's not obvious all your settings will be erased (radio presets, time etc.)
Old Sep 22, 2008 | 11:10 PM
sahiwal007's Avatar
sahiwal007
thanks for the info guys
Old Sep 22, 2008 | 11:34 PM
bboysteele's Avatar
bboysteele
And don't forget about the window reset that you will need to do.
Old Sep 22, 2008 | 11:35 PM
TerribleONE453's Avatar
TerribleONE453
yes make sure you read up on that one or you wont be the happiest kid on the block ^
Old Sep 23, 2008 | 01:45 AM
sahiwal007's Avatar
sahiwal007
so all i have to worry about is my presets being deleted and the windows right? anything else?
Old Sep 23, 2008 | 02:32 PM
sumo8me's Avatar
sumo8me
You should just keep trying the pedal method that way the radio presets wont erase. It took me 20-30 tries before i got it to work. It helped if i used a watch for the timing.
Old Sep 25, 2008 | 01:03 AM
sahiwal007's Avatar
sahiwal007
^ tried atleast 60 times, and no luck
vamarris
Dec 9, 2018 11:10 AM
delfinparis
Oct 8, 2015 06:06 PM
dedmanchan
Sep 24, 2015 11:25 PM
Raffay Khan
Intake and Exhaust
Sep 14, 2015 10:47 PM
