JL W7 10" in a g37?
Old Mar 17, 2008 | 01:42 AM
bboysteele's Avatar
bboysteele
You shouldn't need to. The head unit is actually a pretty good system. You could spend more money and get a better head unit but that would be up to you.
Old Mar 20, 2008 | 11:17 AM
fcarpio's Avatar
fcarpio
Originally Posted by DiamondGCoupe
The W7 is a HUGE sub, if you are planning on using your trunk for anything I would recommend a W6, plenty of bass in half the space! And neither will fit properly in the 4080 enclosure. Take a look at the W5's too.
In my opinon, the W3 sounds much better than the W6. It is kinda SQ (W3) Vs. SPL (W6).
Old Apr 11, 2008 | 02:31 PM
f0ki187's Avatar
f0ki187
There is NO such thing as a W5. But I do have a 12 inch w7 with a custom built box made for the G37. ANYONE can get this. Just go to your local car audio store and tell them the specs of your sub, and ask for a custom fiberglass box. ONLY GO FOR THE BEST FOR YOUR G. Get fiberglass, it's gonna be alot lighter which will save you money in the long run cause gas. I have half my trunk. And it also depends on if you want tight sound, or heavy bass. Check out Caraudio.com and do some research. If you need help LMK ! I can try to help. GOOD LUCK
Old Apr 11, 2008 | 02:36 PM
DiamondGCoupe's Avatar
DiamondGCoupe
Orly..?
http://mobile.jlaudio.com/products_s...hp?page_id=245
Old Apr 11, 2008 | 02:42 PM
MaxToTheG37's Avatar
MaxToTheG37
Super Moderator w/ Boost
Old Apr 11, 2008 | 02:52 PM
IP37's Avatar
IP37
thats a TW5.. not a W5
Old Apr 11, 2008 | 03:01 PM
symalik's Avatar
symalik
I don't think 2 W7's are that much. But sure in a few months, your car will be a rattle box. I have 2 TDX's in my G37, which are very comparable to W7's. Ofcourse they are not in a ported box, and the gain **** on the amp is not even 1/2 way, but I have turned it up. Your rear window will flex (mine did on my G35 for 3 years I owned it, when my system was turned up, in actual boxes for the subs), but that should be no problem. If you want it, go for it. But like some one said above, make sure you listen to it before you buy it.
Old Apr 11, 2008 | 03:02 PM
MaxToTheG37
Thin W5
Old Apr 11, 2008 | 03:24 PM
DiamondGCoupe
Thin W5
Need there be this much debate, either way a "5" does exist.
Old Apr 11, 2008 | 03:39 PM
MaxToTheG37
+1... everyone always calls JLs -double yas...
this will be referred to as a W5 by the majority.....
Old Apr 11, 2008 | 04:53 PM
f0ki187's Avatar
f0ki187
No, they refer the TW5..
Old Apr 12, 2008 | 12:45 AM
serenitynow's Avatar
serenitynow
W5's
I had two 15 W5's in my car back in the day when they did exist... 1994 or so... you'd have to be an old car audio guy like me to remember them, though...
for what it is worth, I have played with both the Image Dynamic ID10V3 and the IDQ10 V3 and they are very impressive for their price points...
Old Apr 15, 2008 | 10:47 PM
bllop's Avatar
bllop
lets say i used the 1 ten inch box from zenclosure with a jl w7 would it do any damage to the sub or would still be okay to use
rbgrant
Buying & Leasing
Nov 12, 2020 11:53 AM
G37 IPL Bryan
Sep 15, 2015 04:40 PM
ThebigJ
Aug 25, 2015 09:22 PM
Zach Stewart
Aug 18, 2015 05:01 PM
