Where to draw the signal from for the sub?
Old Apr 7, 2010 | 11:00 AM
  #121
snaik69's Avatar
snaik69
is there a concensus on where to draw the remote on signal (12v) (when connecting terminals 23-26) or is everyone doing something different?
how about ground? is iasskicker's suggestion the way to go?
Old Apr 7, 2010 | 11:10 AM
  #122
TTZ2G's Avatar
TTZ2G
after reading this thread, seems pretty simple to hook up a sub by splicing or tapping. My question is, since this is for the low's, can't we do this for the highs and splice into somewhere else to connect to an aftermarket amp and replace the ****ty high and mid range speakers?
Old Apr 7, 2010 | 02:09 PM
  #123
finagle69's Avatar
finagle69
if you're using a JL amp, the Bose Amp-On signal is sufficient to turn on the JL amplifier. If you use a different brand of amp, you may need to get switched 12VDC from elsewhere.
for ground, on the right side of the trunk, there's a metal enclosure around some equipment. i unbolted it, ground down the paint, slipped a terminal under the enclosure then bolted through. it's very close to the amp and is a solid conx to ground. closer than the method posted on the previous page.
Old Apr 7, 2010 | 03:45 PM
  #124
snaik69's Avatar
snaik69
Thanks Finagle69....so that would be terminal 20 "amp. on signal" on B41 harness?
is this whole step neccessary though....amp has a signal sensing on/off switch and JL website reads..."Signal-sensing turn-on is activated on the amplifier to eliminate the need to run a remote turn-on lead"
Old Apr 7, 2010 | 04:54 PM
  #125
finagle69's Avatar
finagle69
^ signal sensing is hit or miss on mine. I'm a fan of hardwiring discrete signals anyway.
Old Apr 7, 2010 | 07:32 PM
  #126
Haji's Avatar
Haji
For my amp, I hooked up a PAC-TR4 (look it up on eBay, only $15 or so) to a wire that I tapped from number 20 on the harness. No problems whatsoever, gives me a reliable on and I'm using a Hifonics amp which is really picky.
Old Apr 7, 2010 | 07:50 PM
  #127
snaik69's Avatar
snaik69
actually, i think ive read before that it does not always pick signal up....its not that much work in order to be sure...good advice!
Old Apr 7, 2010 | 10:16 PM
  #128
Haji's Avatar
Haji
And if you upgrade in the future, it's good to get the connections right the first time.
Oh and as for finagles ground, my amp is mounted right near the seat so it was less than a foot away. Remember, you want the ground less than 2 feet, the shorter the better. And for wires I highly suggest KnuKonceptz, little more expensive, but they are absolutely wonderful.
Old Apr 8, 2010 | 12:52 AM
  #129
JLai's Avatar
JLai
I tapped the Bose sub amp power-on signal for my JL 500/1v2 with no problems what so ever.
Old Apr 8, 2010 | 03:13 AM
  #130
STOOF's Avatar
STOOF
I just ran a remote wire to my fuse box, off the cig lighter or something thats switched. So if the car is ON the amp is on.
So i connected the amp to 23-26 and idk it hits nice but doesnt seem like its hitting as hard as before. I had the box out for a LONG time so idk maybe its just me.
Also right when i start the car i hear a real quick thud from the sub. Anyone else get this?
Old Apr 8, 2010 | 03:17 AM
  #131
STOOF's Avatar
STOOF
Originally Posted by iasskicker
I just used wire taps and tapped my rcas into 23-26, mkaing sure to match the left, right, positive and negative and I have perfect signal.
And I already told stoof, but I found an awesome grounding spot. If you remove the piece circled here and put your ring terminal under it. There's just two 10mm to remove I think:
lol whatya mean you told me? i told you! haha i crossed out your red circles and drew in the blue one.
Old Apr 8, 2010 | 08:56 AM
  #132
Haji's Avatar
Haji
Yeah you gave me the spot, but I told you a better way to make it a solid ground :P.
Teamwork stoof, teamwork.
Old Apr 8, 2010 | 11:53 AM
  #133
finagle69's Avatar
finagle69
That's true. it all depends on where you mount the amp. I mounted mine under the right trim piece closest to the back of the car (rear bumper). It's stealth mounted under there. Therefore, my ground location is closer to the amp than yours.
As for you wires, the Cu in those cables is no different than the Cu in cables you can buy at Fry's. I'm an EE.... trust me. Cu is Cu... don't be fooled by higher prices and marketing.
Old Apr 8, 2010 | 12:33 PM
  #134
redfoster's Avatar
redfoster
If the Bose ON signal doesn't work for some guys (like me, although anyone using JL shouldn't have a problem) you can use the pink wire off the Sat Radio box which is the full 12V+ Switched ACC. I'll try and find the wire number from the service manual.
Old Apr 8, 2010 | 02:48 PM
  #135
snaik69's Avatar
snaik69
Stoof, iasskicker mentioned picking up a PAC-TR4-low voltage turn on trigger ($15-20)....i read up on it...it gives you a one second delay on vehicle power up...in order to avoid "pops"....
