Where to draw the signal from for the sub?
Old Jan 4, 2010 | 04:56 PM
  #91
cullan's Avatar
cullan
One more thing:
23,24,25,26 are the rear head unit outputs
33,34,35,36 are the front head unit outputs
You can use either pair, but you may want to choose based on whether you like to fade front to rear
Old Jan 4, 2010 | 06:10 PM
  #92
JLai's Avatar
JLai
Originally Posted by cullan
I would highly recommend using the head unit output for an input into a subwoofer amp. I believe these are wires 23,24,25,26. In the audio video section there is a Bose Wiring breakdown thread. I assume your amp has a crossover on it which will do a better job of filtering the clean signal from the head unit.
You really should be able to put the left and right into you amp and have it do the summing for you.
Wouldn't it make more sense to take from the B43 "Woofer Amp" using the headunit output "sound signal woofer (+)" and headunit output "sound signal woofer (-)" signals, since I'm just hooking up a subwoofer and nothing else? If I'm not mistaken, connections 23,24,24,26 go to regular speaker connections.
I was almost certain I was supposed to tap into #8 & #9...then use #3 for my remote on. Now I'm confused again...
Old Jan 4, 2010 | 06:28 PM
  #93
cullan's Avatar
cullan
Some people have used the woofer out for the sub amp high-level input. I personally think it's a lot better to just use the clean signal from the head unit. The woofer output already has Bose signal processing applied to it.
Here is what is happening...
The low level signal comes from the head unit to the bose amp (Rear 23-26, Front 33-36).
The Bose amp then adds it's processing, amplifies the signal (now it's high level), and powers the woofer through 8 and 9.
By using wires 8 and 9 you will need to use a high to low-level convertor (some amps have this built in). It doesn't make any sense to convert it to low level when you already have it right there.
I think most audio professionals would agree with me on this. Plus, I don't think you really want the additional Bose processing applied to your subwoofer. There might be a high pass filter applied which might take some of the low frequencies away.
Old Jan 4, 2010 | 07:32 PM
  #94
JLai's Avatar
JLai
OHHHHHHH...Damn light bulb just went off.
Did not know that B43 was post Bose amp. That's why I was confused. So B41 (Rear 23-26) is pre-amp...that's why its cleaner. Makes sense now. Thanks!
Would increasing the bass setting on the headunit affect the bass level on the aftermarket sub if I were to connect 23-26?
Old Jan 4, 2010 | 07:59 PM
  #95
cullan's Avatar
cullan
Yes, 23-26 and 33-36 are pre outs from the head unit. It looks like 8-9 *might* be line level from the diagram, but I just don't know. It could be stepped up or down. And I assume the processing is all done to the signal before it is given to the sub amp.
I am not positive on this, but I believe the bass and treble ***** on the unit do affect the line level outputs. That is how I have mine set up and I believe it does affect the signal when I change the eq settings on the head unit.
There are always additional filters applied by BOSE though. Some sort of equalization and crossovers typically at the amp.
Try experimenting with both methods and use whichever suits your needs better. I was just throwing in my thoughts regarding the line outputs. If you find that 8 and 9 are more suitable then post that here afterwards.
We are actually quite lucky that our setups are the way they are. It's sure nice being able to add a sub so easily. The signal and remote turn on are already in the trunk. Just add power.
Old Jan 8, 2010 | 02:12 AM
  #96
Dieseldoug22's Avatar
Dieseldoug22
I think we discussed this earlier. If memory serves the signal coming from the head unit is a digital signal. Meaning you would need a pricey D-A converter. Most amps won't be able to process the digital signal. And be careful the remote turn on is only 10 volt not 12 volt. May cause problems.
Old Jan 8, 2010 | 08:15 AM
  #97
JLai's Avatar
JLai
So are we back to tapping lines 8 & 9?
Here's a more appropriate question...who HAS tapped 23-26 and what amp did you use?
Old Jan 8, 2010 | 12:23 PM
  #98
cullan's Avatar
cullan
The signal coming from the head unit is not digital. It is line level analog.
I have tapped 33-36 (Front output) for use with my JL Audio amp and it works great. 23-26 is rear output and will work the same way. 8-9 are output from the first Bose amp to the second Bose "woofer" amp. They *may* work, but *may* have added processing added.
Old Jan 9, 2010 | 02:31 PM
  #99
Dieseldoug22
Gotcha. I couldn't remember if it was or not. People have done it both ways. Of course an unmolested signal is always better.
Old Feb 1, 2010 | 02:55 PM
  #100
JLai's Avatar
JLai
Just an update:
Got my system in yesterday. I tapped into 23-26 and it works great. The headunit bass setting does affect the bass. As a matter of fact, I prefer it on headunit bass +2 or 3 before boost.
Old Feb 2, 2010 | 02:53 AM
  #101
Dieseldoug22
I'm glad it all worked out for you.
Old Mar 29, 2010 | 03:49 PM
  #102
jbrady3324's Avatar
jbrady3324
Having a tough time figuring out if you guys are replacing the wires from the HU to the amp? Is this a necessary step?
also, has anyone tried wiring the rear 6x9 woofer for mid-bass?
Old Mar 29, 2010 | 03:56 PM
  #103
snaik69's Avatar
snaik69
go back and read this thread....you will be tapping into the wires that are coming from the HU to the amp...which would be done at the amp location....under trunk...no need to replace anything...
Old Mar 30, 2010 | 02:02 PM
  #104
jbrady3324's Avatar
jbrady3324
Thanks man
Old Apr 4, 2010 | 07:35 PM
  #105
redfoster's Avatar
redfoster
Originally Posted by shepa
what wire do i need to splice for me amp turn on wire?
I used the pink wire off the Satt Radio box which is a true 12V ACC wire. The Bose turn on/remote lines only go to 10V.
Originally Posted by Dipstix6996
Where did you run your power wire at?
Nevermind I found a nice place to run it. It was a pain but it works. Now i need to hook up my amp. Hopefully I get the right wires to draw a signal for my amp
Run it down the passenger side, it fits perfectly into the factory harness clips an up into the grommet hole to the battery compartment. Takes only minutes to do.
Originally Posted by leeladisky
I have the B(l)ose system and I haven't seen anyone discuss a way to reduce the muddy sound of the system. Just adding a sub will increase base, but by not removing some from the front speakers simultaneously, it will just be muddy with more bass! Can anyone point me in the direction of a wiring harness that will allow me to tap the signal before the B(l)ose amps, run it into a JL 500/1 amp where I can crossover the sub frequencies, and then go back into the B(l)ose amp? I would like to do this using wiring harnesses to minimize or eliminate cutting...is this possible????
Lee
Take the full range pre-amp signals (see the sticky for the wire harness layout). All the Bose crappy EQing is done at the amp, not the HU. If you want EQing there are plenty of things like the BitOne to tune the sound, but to save a few dollars run the full range signal to the amp and hook up some crossovers. The sound will be night and day versus the existing 'Blose' setup.
