Electrical Problem - What Have I done!
Old 08-04-2015, 07:13 PM
GXXXVII
GXXXVII's Avatar
Hello people - I own a beautiful 2010 G37S 6MT. I had installed a Valentine radar detector in my car and it has worked great for over a year now. It is plugged in behind the rear view mirror. Well I was messing around there trying to make the wires look better and something bad happened! I may have shorted the wires together not sure.
The mirror quit putting out voltage and I noticed the Compass indicator was not working. Then I went to back out of the garage and my backup camera did not come on. My air conditioner buttons stopped working also - what the heck. I checked the fuses in the driver side panel and did not see anything amiss. I checked the fuses by the battery and did not see anything wrong there either. I disconnected the battery for an hour and restarted the car and still have all of the same issues. I guess I could go back and check the fuses again....are there other fuse locations in this car. Im stumped on this and Im pretty mechanical - please help - all ideas welcome!
Old 08-04-2015, 11:00 PM
JSolo
Just say no!!!!!
JSolo's Avatar
Did you visually check them or with a meter?
IIRC, there are 3 fuse/relay boxes, driver side kick panel (left of dummy pedal), next to the battery and hood area driver side.
Old 08-05-2015, 12:00 AM
micafd3s
micafd3s's Avatar
does it help if the v1 is disconnected... mine has a fuse on the plug that goes to the lighter...
Old 08-05-2015, 10:33 PM
crookncastle
crookncastle's Avatar
most likely a blown fuse. check all fuses with a multimeter
Old 08-06-2015, 01:37 PM
telcoman
telcoman's Avatar
What he said
Check out the FSM
You should have read this first before messing with wires
http://www.nicoclub.com/FSM/G37/Sedan/2010/INL.pdf
"BCM turns applicable lamps OFF depending on the vehicle condition. This function prevents the battery
from over-discharging if the driver neglect turning OFF the any lamps.
Applicable lamps
• Map lamp
• Personal lamp
• Step lamp
• Trunk room lamp
• Vanity mirror lamp"
If you don't have a meter and are unable to troubleshoot the BCM, a trip to the dealer may be in your future
Good luck
Telcoman
Old 08-07-2015, 02:32 AM
drkay
drkay's Avatar
A similar thing happened to me a while ago. I was also messing with the wires connected to the back of the mirror to my radar detector as. What you were playing with the wires while the ignition was on? My mirror stopped working along with the heated seats, heater, all gauges, and I could not shift out of park. It was a fuse in the drivers footwell. I cannot think of the name of the fuse right now but I recall it was third or fourth from the top in the left column of fuses. It was a 10 amp fuse. I will take a look at it tomorrow morning and post back.
Old 08-08-2015, 01:10 AM
drkay
drkay's Avatar
Please check fuse: ELEC PARTS (BATT)
Read my post above. . .
Old 09-29-2015, 10:57 PM
misterJm
misterJm's Avatar
how do you get this fuse out? It has that big thing on top of it.
Old 09-30-2015, 12:18 PM
drkay
drkay's Avatar
I'm not sure what the "big thing" is that you are referring to. You remove the cover over the fuse box and Infiniti provides a fuse puller to help get the fuse out. Or you can use needle nose pliers with gentle pressure.
Old 03-04-2019, 01:59 PM
iVector
iVector's Avatar
I just had this issue, but my car keeps blowing fuses when starting.
Old 03-04-2019, 07:22 PM
Epiphany
Epiphany's Avatar
Then you either have a short or you've hooked up something that's pulling too much power. Go back and double check everything is hooked up correctly and nothing is touching that shouldn't be.
Old 12-11-2021, 08:58 AM
Dman55
Dman55's Avatar
My Car Doing The Same Thing No Rpms No Gas Mileage No Speedometer Car Won’t Shift Outta Park It’s Very Hard To Do Don’t Know What’s Wrong With It
vamarris
12-09-2018 11:10 AM
butwhatuptho
10-04-2015 07:51 PM
MrRiv
09-29-2015 04:59 PM
k19g37x
09-29-2015 02:46 PM
Quick Reply: Electrical Problem - What Have I done!
