Help Wheel offset
Old Apr 18, 2019 | 07:09 AM
How16's Avatar
How16
Wheel offset
Hello this is my first post! My name is Hunter and I have a 2013 G37x Sedan in moonlight white. It’s finally time for my first purchase!
I am interested in purchasing Konig Ampliform 18x8.5 wheels from summit racing. The two offsets they offer are +35mm and +45 mm.
My question is will both of these sizes work? And if so are their any advantages to one over the other?
Old Apr 20, 2019 | 04:00 AM
Said Amir's Avatar
Said Amir
I had this trouble when looking for rims on my g37xs, but I would get +35 it will be flush with the front fenders but it will be a bit tucked in the rear of the car. If you get +45 they will be closer to the inside of the fender. I have 19x8.5 +35 square set up, and since I have the big brakes I had to go +35 to fit over them. My alignment is -0.5 up front, and -1 in the rear if that helps. Also no rubbing issue, and I am lowered on swift springs. As far as performance wise goes I am not educated on it to say much about it, but it will play a bit with your suspension geometry but going to a +35 from a +43 offset did not impact the drive of it. Unless you go too a +20 then it would impact the suspension geometry a lot more since the rims a lot further away from the center of the wheel hub.
Old Apr 20, 2019 | 04:02 AM
Said Amir's Avatar
Said Amir
Old Apr 20, 2019 | 08:55 AM
Yep, what Mr Amir said^^^ +35, and you can run 245/45/18s all around for a nice fit.
Welcome to the site!
Old Apr 20, 2019 | 12:01 PM
How16's Avatar
How16
Okay awesome thanks for the help!!
Old Apr 20, 2019 | 04:20 PM
Said Amir's Avatar
Said Amir
Old May 1, 2019 | 02:12 AM
TLeo_IPL37's Avatar
TLeo_IPL37
Konig Ampliform wheels
Same here. I got an IPL G37 2011 and I am looking to purchase these Konig Ampliform wheels in the near future. I hope they can clear akebono bbk
Here is my IPL ! My IG is @tleo_ipl37. I’m from Middletown Delaware!
Old May 1, 2019 | 09:21 AM
Nice IPL!
These Konigs in 20" clear Akebonos, but I'd contact the vendor and see if they can verify that the Ampliforms will clear in the size you're wanting.
https://www.myg37.com/forums/brakes-...ml#post4240708
Old May 1, 2019 | 03:00 PM
TLeo_IPL37's Avatar
TLeo_IPL37
Nice IPL!
word. I was looking into 18-19” but I’m definitely going to look into this
Old May 1, 2019 | 04:00 PM
Evorus5's Avatar
Evorus5
Are you looking to sell the IPL wheels?
Old May 1, 2019 | 04:17 PM
slartibartfast's Avatar
slartibartfast
The wheel spec changes mentioned here do not much affect suspension geometry. Scrub radius is a tad longer and wheel rate could change a tiny bit, but neither are sensible at the steering wheel or seat bottom unless you're a professional racer. You won't need to get an alignment.
Old May 1, 2019 | 05:39 PM
TLeo_IPL37's Avatar
TLeo_IPL37
no I can’t do that. I like them a lot lol
Old May 9, 2019 | 10:08 AM
SonicVQ's Avatar
SonicVQ
My experience has been a little different.
On my 11 Sport Sedan, with a 35 mm offset, there is much more tugging on the steering wheel under braking on uneven surfaces, compared to the stock 45mm offset and
I find the initial turn in is a little more "numb".
I am on the hunt for 19 x 8.5 rims and will only look at 45mm offsets.... Right now, Enkei TFRs are at the top of my list
PS, Yes I am too old to care about "flush fit" and "poke". I like my suspension to work as designed
Old May 9, 2019 | 01:57 PM
slartibartfast
Originally Posted by SonicVQ
My experience has been a little different.On my 11 Sport Sedan, with a 35 mm offset, there is much more tugging on the steering wheel under braking on uneven surfaces, compared to the stock 45mm offset and I find the initial turn in is a little more "numb".
I suspect tire difference could be the culprit here, especially if they were wider than the stock front tires.
Old May 9, 2019 | 02:54 PM
SonicVQ's Avatar
SonicVQ
I should have given more details... both front tires were 225-50-18 in the above example.
The 35mm offset rim is 8" wide, the stock rim is 7.5" wide with an offset of 45mm.
Here is a visual on how they compare:
• Orange is stock 18 x 7.5 ET45
• Green is 18 x 8 ET 35
(graphic from: https://www.willtheyfit.com)
In this example, the outer part of the rim will be 16.4mm further out (poke) compared to stock and the inner part of the rim is 3.7mm moved outward.
The factory offset will do its best to "centre" the forces on the wheel under braking resulting in minimal steering wheel shake under braking on uneven surfaces.
If you want to compare your own rims and tire diameter, pop over to: https://www.willtheyfit.com
mjnoles1
Jan 3, 2016 01:43 PM
IP37
Mar 23, 2014 07:32 PM
MaxdOut
Aug 17, 2009 01:14 PM
m500
The M - Spot
Feb 23, 2006 01:14 PM
