Diagnosing why my g screeches on sharp turns, even slow ones?
Old Sep 8, 2018 | 04:21 PM
iddqd's Avatar
iddqd
Hey there. I used to run oem tire fitment Bridgestone S-04 poles but swapped tires and wheels for nismos which came with nexen n5000 plus tires which are 245/40/19 all around. I noticed that I get a screeching sound on any sharp turns I make and even when I do a slow u turn in a parking lot. It's not a big deal just slightly annoying.
Is this just the fact they aren't grippy summer tires or perhaps something else I should diagnose? The car itself is a 2013 and still young at 37k miles. I'm about to go ahead and get a new set of summer tires (front 245/40/19 rear 275/35/19) off of tire rack since I'm assuming it's the wheels and sell/store these nexen tires.
Thanks for any input!
Old Sep 8, 2018 | 05:25 PM
stealthee's Avatar
stealthee
Squeely tires on turns usually indicates poor alignment.
Old Sep 8, 2018 | 05:31 PM
iddqd's Avatar
iddqd
Ah thank you! I'll go get one once I install these eibach springs and sway bars.
Old Sep 8, 2018 | 11:22 PM
codeflux's Avatar
codeflux
20 Year Member
nexen n5000 plus are grand touring all season - https://www.nexentireusa.com/tires/n5000_plus
these aren't great performance tires, so i'm not surprised they squeal for you.
Old Sep 9, 2018 | 12:17 AM
stealthee's Avatar
stealthee
Just because they are grand touring and not performance tires makes no difference in tire squeal. I've run grand touring tires a number of times over the years and never had squeal
Old Sep 9, 2018 | 01:42 AM
slartibartfast's Avatar
slartibartfast
Tires can indeed be the source of your squealing, all-season or not. My Michelin PSS3 squeal... at the track.
That said, check that alignment first. Excessive toe in either direction can cause the inside tire to fight the turn imposed by the outside tire.
Old Sep 9, 2018 | 03:03 PM
iddqd's Avatar
iddqd
Thanks all. I'll go ahead and get an alignment tomorrow after work and see where it stands. Hopefully that's the issue. It's mainly for left turns even when not sharp. Any basic wide turn. A loud, quick squeal would go off. I've been reading threads and see many variables that it can. My assumption is it's just alignment related since it happened right when I switched tires + wheels.
bgoodman
16
Oct 26, 2019 11:46 AM
Triksterism
Jan 8, 2018 11:00 AM
babskyline
Jun 19, 2017 02:31 PM
Samer Serhan
Mar 14, 2014 11:51 PM
