Need help diagnosing a problem
Good day everyone. My G37x (2010) is at around 60,000 KM
Lately I've been noticing a very rough idle, as in when im stopped on D, my seat is almost shaking, and the engine makes a wierd sound (sounds like a school bus at idle engine sound), but its not very easy to hear. I don't seem to have any problems at WOT (I should mention I do sense a very, very little delay in the acceleration). I'm not a tech, but I opened the hood today while it was running and the engine did not sound normal at all.
Only mods I've done are installed FI Cats half a year ago. This problem was just noticed maybe 2 weeks ago
Any guesses?
Thank you
Any guesses?
Thank you
Like I said I don't have a background. I have no CEL, and no idea how to pull codes, and I'm quite far from a dealer atm. Wanted to see if its something that maybe someone else has experienced. I've read it could be MAF sensor related etc, but again, I wouldn't know.
When was the last time they were changed and how many miles are on them?
Might be a good place to start.
Telcoman
OP, I've also been experiencing similar symptoms and, like Telcoman mentioned, cleaning my air filters helped to minimize the loud idle a bit. However, I didn't have a rough idle so I can't comment on that.
Have you tried going to an autozone or similar parts store and asked to have a diagnostic test run to see what, if any, codes it's throwing? Most parts stores will do it for free or even allow you to do it yourself if you want. I had a '06 galant gts for awhile and I started to have a real rough idle and small delay or loss of power when accelerating. It ended up being an ignition coil that went out causing a missfire of one of the cylinders.
I did have another quesiton. While in the hood, I noticed the coolant reservoir was practically empty, just a bit in the bottom. Is that a normal level? No CEL
I only did an oil replacement last month.
+1 on this! The one and only time I had a vehicle at jiffy lube I done it because I had a free coupon. They tried telling me my truck, which was only like 18 months old, needed a new belt(s). I asked them to show me which ones and then for some odd reason they couldn't find the one(s) that was worn........
