Stock 19s Max Tire size??
Old May 24, 2018 | 06:47 PM
iTzCloud's Avatar
iTzCloud
Hey guys, I tried looking around but I need a quick answer. I've got a 2012 G37s with the stock 19 enkies and was wondering what's the widest tire I can go on the rear? I've got no spacers or coils. Completely stock. And I've got 225 45 on the front atm. Thanks!
Old May 24, 2018 | 07:08 PM
user 3587587's Avatar
user 3587587
255 are the widest I've seen anyone go with the stock sport rims, even with spacers.
Old May 24, 2018 | 08:31 PM
bPChaos's Avatar
bPChaos
I've run a 245/40/19 on the front and 275/35/19 on the stock coupe rears. It will depend on the tire you run (some run wider than others), but they fit fine, if a bit bulged.
Old May 24, 2018 | 09:53 PM
Baadnewsburr's Avatar
Baadnewsburr
most say 275 is the max on the rears but have been running 285s for a few years.
It will also depend on how you want it to look (some say 285 is "bulgy" some say anything above 245 doesn't have enough stretch....
It will also depend on the specific tire, I've come across more than a half inch variance in tread width on the exact same size/ratio tires depending on the specific model and brand of the tire..check the tire specs fore example:
Pilot super sport 275/35/19 = 9.5in tread width and Pilot sport 4s 275/35/19 = 9.7 (or 9.8) in tread width
Old May 25, 2018 | 05:52 AM
Lego_Maniac's Avatar
Lego_Maniac
+1
I've been running these sizes for 3+ years, lowered on Swift springs with no issues.
Old May 25, 2018 | 06:09 AM
Surfnazi's Avatar
Surfnazi
I run 245 and 275
Old May 25, 2018 | 02:35 PM
slartibartfast's Avatar
slartibartfast
Tire Rack lists manufacturer's recommended wheel size for each tire. Find a tire you think might fit then check that spec. For Enkei 19s, 245 is about optimum up front for sidewall stiffness and contact patch while 285 is about as wide as I would run in the rear.
Old May 25, 2018 | 11:44 PM
Surfnazi's Avatar
Surfnazi
You can get rubbing issues going 285 if you dont plan right
Old May 29, 2018 | 09:53 PM
saywat?'s Avatar
saywat?
u guys really like that bulgy look huh
Old May 30, 2018 | 01:22 AM
slartibartfast
For me, it's about contact patch. Looks are for hard parkers.
Old May 30, 2018 | 06:26 AM
saywat?'s Avatar
saywat?
I jus rather have wide tires on wide wheels.
Old May 30, 2018 | 01:56 PM
Surfnazi's Avatar
Surfnazi
245 275 on stock 19s isn't bulging. I got 1 g with s04s another g with pilots sport as3 plus both have no rubbing issues or bulge
Old May 30, 2018 | 02:03 PM
saywat?'s Avatar
saywat?
i tried 245 in the front. like, i did not.
19"
248
Jun 10, 2025 08:21 AM
THMotorsports
Brakes/Suspension
1991
Nov 24, 2018 12:02 AM
vett26
Intake and Exhaust
May 24, 2018 07:50 PM
main_shoby
Sep 22, 2016 11:49 AM
Obodiah
Sep 21, 2016 08:15 AM
