AWD and Staggered Set Up
What sup guys, I'm about to buy some used wheels with some tires on them, the specs are:
Fronts:
20" x 9.5 +45 offset
255/35/20 tires
Rears:
20" x 10.5 +25 offset
285/30/20 tires
After using the Tire Rim Calculator The Diameter difference is -0.3" (-1.10%)
I was wondering if I could run this set up on my G37x without causing any problems?
Fronts:
255/35/20 tires
Rears:
285/30/20 tires
fronts will work, rears will be poking over an inch outside the fenders, if they were +45 instead of +25 they would work, and front tires should be 245/35 for best diameter variance. Save those wheels for the coupe guys, not worth the work to make those fit.
laklein
Sep 28, 2009 05:24 PM
J2S2M
Wheel & Tires
16
Nov 30, 2008 04:17 PM
