Rohana RC7 for G37 AWD COUPE
Old Mar 7, 2018 | 03:55 PM
BornsinnerM's Avatar
BornsinnerM
Lightbulb Rohana RC7 for G37 AWD COUPE
Looking to get most aggressive setup I can get away with without doing fender work and not have any rubbing. For the Rohana RC7 20x10 & 20x11 fitment. If I need to do fender work I will but currently it’s not dropped on anything(which it will be soon on springs or coils) and I’m kinda on the fence whether or not to do a square setup with 20x10. I hate the stretch tire look. So far I have a AWD so to not mess up the rolling diameter i configured a setup for Front: 245/35/20 and Rear: 275/35/20. But was wondering if Front: 255/35/20 and Rear: 285/30/20 make a difference. Im such a newbie and there’s so many blogs leading all over I can’t find the right page for information.
Old Mar 7, 2018 | 04:25 PM
Here's a list of the best tire combos for AWD staggered sets~
https://www.myg37.com/forums/brakes-...ml#post3992771
Here's about the most aggressive you can go without fender work squared up w/ camber close to spec 20x10.5 +25 on 275/30s
Old Mar 7, 2018 | 04:57 PM
BornsinnerM
Thanks man. I was just on one of the few blogs you replied on thanks! I’m looking for that exact fit you just showed in the image.
Old Mar 7, 2018 | 04:58 PM
BornsinnerM
I wish I could get away with the 11 inch but I also may plan on gettting it on coils so what would I have to adjust ?
Old Mar 7, 2018 | 07:51 PM
You could get by on 11" wheels depending on offset, but more than likely you'd have to run a stretched 275, and then a stretched 245 on a 10" front for your AWD system to run ok.
Looking at the offsets the 20x10 +25 running a 275/30 all around would get you a similar fit to that above G but you'll have an additional 6mm in from the fenders. This should allow you to keep your camber in-spec as you lower your G.
You will need front & rear camber kits to keep your alignment proper as you lower, and the more you drop the more help you need
Old Mar 28, 2018 | 03:28 PM
Gaspeed's Avatar
Gaspeed
My car is not AWD but I'm running Rohana RC7's. I have 20x10 in the front and 20x11 in the rear on 245/3520 and 275/30/20. It's just a pretty mild stretch and nothing even close to crazy. I'm on air suspension so for my drive height I did have to shave off the rear bumper brackets and roll my front fenders only because my drive height is pretty low.
Old Mar 28, 2018 | 08:06 PM
Always liked those shots of your G^^^^What offsets are you running and what camber are you at during drive height?
Old Mar 29, 2018 | 06:31 PM
BornsinnerM
Thumbs up
You have a great looking G, those wheels are dope! although I dont plan on dropping it that low, maybe F:1.9 R:1.6.. but I need a setup without tires stretched. im on the Northeastern where you can go swimming in potholes and the sidewall looks iffy.
Old May 29, 2020 | 05:21 PM
vqdrew's Avatar
vqdrew
Hey bro what was your offset in the front? And did it clear bbk? Thanks
Old Nov 5, 2020 | 07:38 PM
Vick Sookhdeo's Avatar
Vick Sookhdeo
G37 convertible
Hi can I do the rc7 20x9 32off set in front n 20x11 28offset rear?
2011-G
18
Sep 12, 2016 08:42 PM
em1990
Jul 15, 2015 11:17 AM
Aspire Motoring
Wheel & Tires
47
May 1, 2015 07:05 PM
