Rubbing with 275s
Rubbing with 275s
Just had my rear tires replaced and noticed that the shocks have a spot worn on the side.
The inside edge of the tire is worn as well.
I am currently on the stock sport suspension, sport wheels, and have no spacers installed.
Alignment seems fine as well.
Anyone have any ideas as to what the issue may be?
It seems obvious that the stock wheel offset causes tire/damper interference while using 275 width. Either use a thin spacer or buy stock-sized wheels with 5mm or so less offset.
Hmmm, that sounds strange, I was running 20x10+45 on 295s and they cleared just fine on my RWD sedan. Or are you running the stock 18s on a sedan, that could be a different fitment vs the 19" on a coupe.
Running the stock sport wheels:
19*8.5 Front with 245/40/ZR19
19*9 Rear with 275/35/ZR19
