Help Wheel swap
Old Apr 7, 2016 | 10:51 PM
Romanog37x's Avatar
Romanog37x
Wheel swap
Hi everyone I need some help in deciding on what rims I should get for my 2013 g37x sedan. I have,already for the front 20×8.5 +20 offset and for the rear 20×10 +40 offset but since the car is awd. I want to put 20×10 +40 offset all around and would like to use tire profile 245/35/20. The car is on stock suspension I'm not going to lower or camber. Do anyone have an idea if my 20×10 all around is going to work would it rub on fenders or would it poke out. I appreciate all inquiries and also if anyone running same set up can u post a picture so I can see what it will look like. Thanks in advance!!!!
Old Apr 7, 2016 | 11:08 PM
kimmspeed's Avatar
kimmspeed
Start here:
https://www.myg37.com/forums/wheels-...on-thread.html
Old Apr 7, 2016 | 11:12 PM
the93owner's Avatar
the93owner
20x10 +40 on all corners will poke out. And 245/35/20 tires will be stretched. Best to go with 20x8.5 with those tires especially since you won't be lowered or cambered. Use the tire/rim calculator to help decide how much your wheels will poke.
Old Apr 8, 2016 | 09:30 AM
VenomGT9's Avatar
VenomGT9
20s on a stock sedan will look funky...and as mentioned the 10in will stick out a bit.
DeepakG37
Apr 13, 2016 12:30 AM
JYobbi34
Mar 24, 2016 08:54 AM
Lamify
Mar 19, 2016 04:30 AM
evil-G-nius
Mar 14, 2016 06:04 PM
Rr1982
Mar 11, 2016 11:39 PM
