Help Square set up on a RWD. Which is the correct way to rotate tires?
Old May 10, 2016 | 02:16 AM
*ICE*'s Avatar
*ICE*
Hey guys,
I'm running a square setup on my RWD, 245/35/20 all the way around. It's been about 6-7k miles since I installed them new on the car and a few shop suggested that I should rotate them.
I found some instructions online, see below. Which way is the correct way?
Square set up on a RWD. Which is the correct way to rotate tires?-bwoal1x.png
Thanks in advance!
Old May 10, 2016 | 07:26 AM
ColumbiaSkinny's Avatar
ColumbiaSkinny
I've always done the criss-cross pattern shown in the first picture.
Driver side rear switches with passenger side front....
Passenger side rear switches with driver side front....
I don't see anything wrong with doing it like the "All Vehicles FRONT" below the first picture suggest as well. Just as long as your rears are switched with your fronts you should be good to go.
Reason, your rears where more in the middle of the tire and not on the outer edges. Your fronts, because they steer you and turn, can get worn on the outer edges while the center of the tire still has good tread depth on it. Switching them up front to back helps even that wear process out a little more and prolongs the life of the tire and tread....
Old May 10, 2016 | 08:14 AM
jfisher's Avatar
jfisher
The middle right is the correct way to rotate your setup. That's going to ensure the longest life out of your tires. Are your tires directional?
Old May 10, 2016 | 10:29 AM
VenomGT9's Avatar
VenomGT9
Agreed, middle right
Old May 10, 2016 | 05:16 PM
*ICE*'s Avatar
*ICE*
yes. my Hankook V12 is directional so i guess I can only do front to back and back to front. Can't do left to right.
Old May 10, 2016 | 09:39 PM
Ricio1991's Avatar
Ricio1991
Originally Posted by *ICE*
Hey guys,
Thanks in advance!
I rótate mine every 6k at discount tire , I would see how they do it since I bought them there they come with free rotation
Old May 11, 2016 | 06:11 PM
evil-G-nius's Avatar
evil-G-nius
Yeah, the way you rotate actually depends on the type of tires you have...assuming you have a square setup. Directional tires will dictate which will be the best way to "rotate"
ross7778
Sep 9, 2017 01:07 PM
F23jeff
Jul 14, 2016 06:28 AM
Detailed Image
Lighting/Cleaning Products
May 9, 2016 04:03 PM
Moe_G37x
May 6, 2016 10:41 AM
Moe_G37x
May 5, 2016 01:27 PM
