tire maintenance warning on screen
Old Oct 6, 2015 | 07:54 PM
butwhatuptho's Avatar
butwhatuptho
Ok so after reading review after review i still cant find a solution...
My "maintenance tire" warning comes on every time i start my car... iv reset my maintenance setting iv even disabled them.. iv check all tire pressure... how do i get the warnin off my screen #?!?!?!?!?! Any help guys.
And yes i know its a bs warning t9 rotate my already off set tires... but my tread is fine my tires are fine how do i deactivate this ? Does anybody have the right answer for me?
Old Oct 6, 2015 | 10:12 PM
Landshark's Avatar
Landshark
properly inflate your tires, drive for 5-10 minutes.
if the warning persists, you probably have a bad TPMS sensor.
Old Oct 7, 2015 | 12:10 AM
quakerroatmeal's Avatar
quakerroatmeal
Is this the one that comes on through your cluster/mid display? Take a picture of what you're talking about.
A Maintenance Tire warning has nothing to do with TPMS. Only if your (!) lights up on your cluster.
I'm going to guess it's this light?
If so you'll have to use the two buttons on the right side of the cluster to go through the options and reset it.
Old Oct 7, 2015 | 02:14 AM
evil-G-nius's Avatar
evil-G-nius
You can go into the computer and reset the length of time before the light comes on. So if it is set at 60k you can change the warning to 75k or something like that
Old Oct 7, 2015 | 08:34 AM
Landshark's Avatar
Landshark
i can't read LOL.
18oz Margheritas for $2 last night.
Old Oct 7, 2015 | 12:25 PM
It's a bit clumsy interface to reset the service reminder settings but that sounds like that's your issue. The manual goes through it pretty well, if you just get in there and push buttons you may end up just going back & forth. Especially if you joined Landshark for those 18oz Margaritas, lol.
Old Oct 7, 2015 | 02:43 PM
m3clubracer's Avatar
m3clubracer
Yeah the reset is NOT an obvious choice and NOT mentioned in the manual as a need. So RTFM is N/A in this case.
Old Oct 7, 2015 | 03:53 PM
Landshark's Avatar
Landshark
on headunit --> SETTING button
"Maintenance"
"Tire"
Old Oct 7, 2015 | 04:06 PM
Redfire32's Avatar
Redfire32
Ginger ninja
You guys can't reset this stuff by using your touch screens? I never F with those two little buttons to the top right of the steering wheel. So much easier to us the screen to reset the warning values.
Old Oct 7, 2015 | 04:49 PM
2008G-Man's Avatar
2008G-Man
They are independant of each other, one doesn't reset the other. You can choose not use the guage cluster reminders so they will never go off.
Old Apr 26, 2016 | 08:46 PM
HighTider's Avatar
HighTider
Dot Matrix. I did all that multiple times with no result. And then next time I started the car it was reset. So, maybe that is part of the deal who knows. Manual sucks as far as instructions. Thanks for the reply
Old Apr 26, 2016 | 08:48 PM
HighTider's Avatar
HighTider
Thanks. Would not reset until next time I started the car. Strange.
Old Apr 26, 2016 | 09:19 PM
slartibartfast's Avatar
slartibartfast
You guys can't reset this stuff by using your touch screens...
Touch screen? In a G???
hcag2
Dec 26, 2016 01:09 AM
911turbo
Nov 9, 2015 10:37 PM
nrp
Nov 5, 2015 01:14 PM
OwenC
Oct 23, 2015 03:17 PM
rk325
Oct 13, 2015 01:51 PM
