Nitrogen, where can I buy?
Old Dec 12, 2014 | 03:49 PM
inyquest's Avatar
inyquest
Is there a chain store (NTB, Pep Boys, etc.) that sells nitrogen?
(Or in the SE- Atlanta area)
Thanks
Old Dec 12, 2014 | 09:12 PM
slartibartfast's Avatar
slartibartfast
Waste of money for tires. Good for powering airbrushes, though.
Old Dec 12, 2014 | 11:09 PM
The only time I'd recommend Nitrogen would be for airing up your spare tire since it's a pain to remove & check (since the stem is downward in the trunk) and it's often forgotten for months, even years sometimes
Old Dec 14, 2014 | 12:57 AM
inyquest's Avatar
inyquest
Thanks for your thoughts but it's already a done deal. I just need to find it.
I'm so not the kind of person that does or likes to check and or put air in a tire.
Heck, if they still had full service gas stations I'd be using them.
(Check fluids etc.)
Old Dec 14, 2014 | 01:43 PM
(Check fluids etc.)
Understood.
Not like Nitrogen is a bad thing, it has it's purpose, just not really worth the added cost & hype.
I'm sure most of the big chain shops carry it.
Old Dec 14, 2014 | 03:03 PM
LexiG37's Avatar
LexiG37
Mother Nature gives it to you. Air is 78% nitrogen. Residual air even in a deflated tire will dilute the pure nitrogen the tech inflates with. It's really just a clever way to help misinformed drivers part with their money.
I have a friend that never checks his oil or tire pressure. His car is suffering and I cringe at his laziness. Enjoy your nitrogen.
Old Dec 14, 2014 | 03:09 PM
inyquest's Avatar
inyquest
I cringe every time I see someone add something to their car that's not really very useful in day to day driving in traffic OR that sucks more gas
To each his own.
Thank you
Old Dec 14, 2014 | 05:36 PM
Selym's Avatar
Selym
I've noticed that the coin-operated compressors often seen at gas stations/convenience stores dispense a lot of moisture along with air. This could potentially corrode the alloy wheel. If this happens along the bead, you'll have a slow leak. I've had this happen, buy I can't prove that the moisture came from a coin-operated compressor.
If you use nitrogen to inflate your tires, at least you know it's dry. Costco inflates with nitrogen, and they'll top-up your tires for free.
Old Dec 14, 2014 | 05:46 PM
inyquest's Avatar
inyquest
I'm also thinking that less moisture less issues with the TPMS
Old Dec 14, 2014 | 09:04 PM
Lego_Maniac's Avatar
Lego_Maniac
^^this
If you mix air with nitrogen, they will bleed out your tire and refill it with nitrogen
Old Dec 29, 2014 | 12:03 AM
inyquest's Avatar
inyquest
Me likey
My car sits a lot for days, weeks and it's nice to finally not have the TPMS light on.
(That was driving me crazy!!!!)
37
Oct 17, 2020 11:12 AM
Upscale Speed
Dec 24, 2015 12:00 PM
Dillybar12
Nov 1, 2015 07:23 PM
ajosowiecky
Sep 30, 2015 12:15 PM
