Will 10.5 +35 with 265/35/19 fit and look right in the back?
Old Aug 27, 2014 | 12:35 AM
rollaspeed1's Avatar
rollaspeed1
http://www.aspecwheels.net/index.php?route=product/product&path=20_2873_2899_2923_2925&product_id=619 6
I'm thinking on putting this on my sedan. 8.5 +30 / 10.5 +35.
Will this fit? What do you think, Will it look right?
For the record, I have a gen 2 g35 sedan, not that It matters.
Old Aug 27, 2014 | 12:42 AM
ScrewstonNismo's Avatar
ScrewstonNismo
The fronts would have minimal poke, but a 10.5 inch wide wheel with that offset? I would thiinnkkk that it would poke pretty bad. I'm not an expert by any means though! Just my $0.02. If I'm wrong, someone please provide the correct info.
Old Aug 27, 2014 | 12:53 AM
Sunny G's Avatar
Sunny G
If you are lowered then it will fit if not it will poke
AroundTheG37's Avatar
AroundTheG37
The fronts will be pretty sunk and the rears will poke. Do not buy (and not just for fitment reasons...........).
Old Aug 27, 2014 | 01:01 AM
rollaspeed1
Yeah I'm lowered... currently I'm on 8.5 +34 10 +45 on 275s and it fits real easy.
Attached Thumbnails Will 10.5 +35 with 265/35/19 fit and look right in the back?-20140824_131906.jpg   Will 10.5 +35 with 265/35/19 fit and look right in the back?-img_20140809_160335.jpg   Will 10.5 +35 with 265/35/19 fit and look right in the back?-post_image8.jpg
Old Aug 27, 2014 | 02:14 AM
370 GT's Avatar
370 GT
I run a 275 on 10" +40 in the rear dropped on swifts (-1.5 camber) and the rim still sits a bit proud, at 10.5" +35 I imagine will definatly poke without running some significant negative camber...
Old Aug 27, 2014 | 02:24 AM
rollaspeed1
Dammit I really like those....
Old Aug 27, 2014 | 08:36 AM
OP, you'll be 6mm out for the 1/2" wider rim, 10mm further out w/ the new offset so a net 16mm but your new 265 tire is 5mm in, so a new net of 11mm sticking out from where you are now. If that still works w/ your current setup then OK, but I think your rubber will be right at that fender edge. At least at spec camber that is.
Old Aug 27, 2014 | 10:41 AM
rollaspeed1
Would you do it? I currently have -2 camber all around. What about design wise?
Attached Thumbnails Will 10.5 +35 with 265/35/19 fit and look right in the back?-00o0o_froh3py1uip_600x450.jpg   Will 10.5 +35 with 265/35/19 fit and look right in the back?-01212_1gxjcrrwbnw_600x450.jpg   Will 10.5 +35 with 265/35/19 fit and look right in the back?-00l0l_ixzxjzle2hb_600x450.jpg   Will 10.5 +35 with 265/35/19 fit and look right in the back?-00w0w_b0lwigijjtd_600x450.jpg
Old Aug 27, 2014 | 10:59 AM
AroundTheG37
Not really a fan of the look of the wheels and at that price the quality is probably no bueno as well.
Old Aug 27, 2014 | 11:01 AM
rollaspeed1
Quality isn't my biggest concern. Its a used car and a daily driver. Also, now I'll be doing vinyl wrapping for practice so color may change every now and again. Would be nice to have a set that's neutral in color and uniform in design to fit every color.
Old Aug 27, 2014 | 11:14 AM
AroundTheG37
The ones you you showed above my post are much better looking than the ones you originally linked (which I thought you were asking about).
Old Aug 27, 2014 | 04:49 PM
rollaspeed1
Here are the pics of the stretch on back.
Attached Thumbnails Will 10.5 +35 with 265/35/19 fit and look right in the back?-20140827_112353.jpg   Will 10.5 +35 with 265/35/19 fit and look right in the back?-20140827_112504.jpg
Old Aug 27, 2014 | 07:23 PM
Wheels are a nice design for your G and have a decent concavity to them.
As far as fit, I put the numbers out there for you, just add 11mm to your current fit and that should give you an idea of the look w/ those wheels/tires. Tires can vary in widths from brand to brand so always best to have a little extra room available to allow for that.
Old Aug 27, 2014 | 08:36 PM
rollaspeed1
You always know best! ^^^^^^^^^^^^
DOMO
