Fitment question - re drilled wheel?
Old Mar 9, 2014 | 07:54 PM
Ipp391's Avatar
Ipp391
What's up guys. I'm looking into grabbing a set of 20" Miro 111 wheels for my X sedan at a pretty good price but I have a couple concerns..
First, the guy selling these said that these were given to the previous owner as blanks (no bolt pattern) and drilled to 5x114.3. After a little research, these wheels are most common for euro applications and come from the factory with a 5x120 so these wheels with a 5x114.3 would have to have been redrilled. If these were in fact redrilled, does this pose any issues I should be worried about?
Second, these are 20x9.5 +18 all around and I'm not sure about fitment. Per my calculations, i think these will fit nice and flush in the rear but I'm think these may be too aggressive in the front. I'm not opposed to running staggered tire sizes in order to make the fronts fit but I know I need to stay within 3% rolling diameter for the awd. FWIW I will be dropped on Swift springs for now.. Any thoughts?
But man these look nice...
Attachment 102577
Attachment 102578
Attachment 102579
Old Mar 9, 2014 | 10:54 PM
Great looking wheels, unfortunately those offsets are way aggressive for a sedan w/ a traditional drop and stance. If you were slammed, running heavy camber, rolled front fenders, stretched tire sizing it's possible but a lot of work.
Old Mar 10, 2014 | 09:23 AM
ANMVQ's Avatar
ANMVQ
As blnewt said, the +18 wont work. Front 20X8.5 +24. Rear 20X10.5+45. are what I'm running there very tight.
Old Mar 10, 2014 | 11:40 AM
Ipp391's Avatar
Ipp391
What wheels are these? Rohana's ?
Old Mar 10, 2014 | 12:43 PM
ANMVQ's Avatar
ANMVQ
No Rennan C10's 20's just bought them from a member on here and installed them yesterday . The look GOOD , dropped will look super
( thats Wendsday)
Old Mar 10, 2014 | 12:54 PM
guy from norcal's Avatar
guy from norcal
those are sexy wheels
Old Mar 10, 2014 | 02:21 PM
( thats Wendsday)
Glad you got them on, that was a nice deal if I remember correctly. Look forward to some dropped pics, BTW what tire sizes are you running?
Old Mar 10, 2014 | 02:36 PM
ANMVQ's Avatar
ANMVQ
It was , the 245/35/ZR20 and Rear- 275/30/ZR20.
, Didn't change anything. Cant wait for the drop either LOL
Old Mar 10, 2014 | 10:37 PM
dkmura's Avatar
dkmura
20 Year Member
I can't believe no one on here has pointed out the OEM wheel pattern for the G37 is 5 X 114.3. There should be no need for redrilling (which is not recommended in any case) and the OP should be able to at least see if they bolt up properly.
Old Mar 10, 2014 | 10:44 PM
eurtsx's Avatar
eurtsx
Don't redrill. Buy proper fitting wheels and get it done right the first time.
Old Mar 10, 2014 | 11:39 PM
I didn't say anything about the redrilling becasuse he said the previous owner said they were un-drilled blanks that were drilled to the Infiniti 5x114.3 Although the initial post was a bit conflicting
Old Mar 11, 2014 | 08:32 PM
Ipp391's Avatar
Ipp391
Sorry about the confusion.. Basically I was just trying to say that if the guy was mistaken and these were not drilled from blanks, then it is most likely that these were redrilled to a 5x114.3. Just wasnt sure about the integrity of a wheel after it had been redrilled.
Old Mar 11, 2014 | 11:41 PM
dkmura's Avatar
dkmura
20 Year Member
There's more to redrilling a wheel than just the bolt pattern. Even if it was done by a professional, what shape of lug seat was used? If it's different than the conical seat the Infiniti lugs are designed for, you'll need aftermarket lugs, or those fancy wheels could exit the car even after they're torqued to spec.
And don't forget the center bore diameter either- if it's smaller than the G's 66.1 mm center bore, you'll never get the wheels to seat properly. And if the bore is larger, it won't spread the axial loads properly and you'll overload the wheel studs without a bore spacer.
Thedbarz
33
Feb 9, 2016 12:05 AM
pal51961
Jan 16, 2016 08:26 AM
ladydriveng37
Oct 11, 2015 05:23 AM
james6980
Oct 9, 2015 01:28 PM
