2011 G37x with IPL rims
Old Jan 6, 2014 | 11:48 PM
biggigeez's Avatar
biggigeez
Hi, I am interested in getting the 19" IPL rims once spring arrives. I am aware that if I was to purchase these used off a coupe they will be stagger set (19x8.5 and 19x9). With that said can you please advise what combination of tire sizes should be used? If by chance I purchased it off a seller who is willing to include the original tires will they fit?
Moreover, provided that I don't want stagger sets and want to purchase 19x9 all around online (new or used), any recommended sites/dealers?
any help would be greatly appreciated. Thanks!
Old Jan 6, 2014 | 11:54 PM
GoFightNguyen's Avatar
GoFightNguyen
Because Racecar
Originally Posted by biggigeez
Hi, I am interested in getting the 19" IPL rims once spring arrives. I am aware that if I was to purchase these used off a coupe they will be stagger set (19x8.5 and 19x9). With that said can you please advise what combination of tire sizes should be used? If by chance I purchased it off a seller who is willing to include the original tires will they fit? Moreover, provided that I don't want stagger sets and want to purchase 19x9 all around online (new or used), any recommended sites/dealers? any help would be greatly appreciated. Thanks!
As far as I know, there is no IPL sedan. You would have to source four square ipl wheels. You can probably order them from InfinitiPartsUsa.
Old Jan 7, 2014 | 12:18 AM
You could run 245/40/19s all around since the tires will fit 8.5 & 9" rims, they'll just come away from the rim at a bit sharper angle on the 9s, but shouldn't be very noticeable. The diameter of those tires will be less than 1% from your stock diameter so you won't have issues w/ your AWD, traction, & braking systems and your speedometer will be minimally affected. If you have to buy these new there may be other wheel choices at those prices that may be worth a look.
Old Jan 7, 2014 | 12:22 AM
gsm026's Avatar
gsm026
GoFight is correct, no sedan IPL. The only IPL package is on the coupe and it uses staggered 19" rims just like the RWD S coupes. I believe that you could use the stock setup from the IPL coupe on your sedan with no problem. If you don't want staggered, that makes it more difficult because that's the only way they came from the factory.
Old Jan 7, 2014 | 12:29 AM
connoisseurr's Avatar
connoisseurr
Correction - you cannot use staggered setup right from the IPL coupe without purchasing new tires for either the front or rear. The tire sizes that come standard on the staggered coupe wheels will cause so many issues with the AWD system, braking, traction, etc. review what Brad said above.
I have the regular staggered coupe 19s and plan to run a 245/40/19 as Brad mentioned. This size tire will minimally effect the driving systems that the G uses, and won't cause any issues. Just wanted to correct you before OP goes and gets wheels and throws them on.
I refinished these and picked them up from powdercoat today - turned out really nice.
Old Jan 7, 2014 | 12:30 AM
STownSaint's Avatar
STownSaint
OP check the marketplace there was a guy in VA with a square setup FS (with tires)
Old Jan 7, 2014 | 12:36 AM
connoisseurr
Not sure if they're still out there but there were many sets for sale between VA and MD - at least 3 if I'm correct.
Old Jan 7, 2014 | 03:11 PM
biggigeez's Avatar
biggigeez
Thanks everyone who has responded. I have someone locally willing to sell for approx $1500 with 245/40/19s tires all around. If all goes well will post pics!
Old Jan 7, 2014 | 03:14 PM
GoFightNguyen
Because Racecar
That's a pretty good deal if the whole set is still mint.
Old Jan 7, 2014 | 03:37 PM
connoisseurr
I'd agree with this, only if the tires are mint. Otherwise I wouldn't pay more than $1200.
91dx
Aug 1, 2016 10:46 PM
dwhit757
Oct 12, 2015 04:27 AM
timc00k
Sep 5, 2015 05:12 PM
ryang37x
Aug 21, 2015 03:27 PM
