G37 Rim Advice
Old Nov 25, 2013 | 04:09 PM
goblincadet's Avatar
goblincadet
G37 Rim Advice
Hey guys, long time lurker here with my first post! I have a G37x coupe and plan to put rims (CV1s) on my car, but I have a few questions.
I plan to lower my car on Eibach Springs.
I'm considering 19 or 20 inch wheels.
What is a good offset for my car (Id like to have the wheels flush)?
Do I need a camber kit?
What's the purpose of spacers?
What tire dimensions should I use?
Thanks in advance, sorry for being a noob!
Old Nov 25, 2013 | 04:32 PM
tmmueller's Avatar
tmmueller
Have you searched through the official vossen wheel thread? most likely everything you need to know is in it. I also recommend PM'ing Diego as he will tell you exactly what you need to know. Lastly, the eiabach's don't require a camber kit but you will be close to running too much negative camber. Your tires will wear a bit faster is all. If you do a square set-up you may be able to rotate the tires to help prolong the life of them. Spacers should not be necessary if you get the proper wheel and tire set-up. Diego will point you in the right direction for sure.
Old Nov 25, 2013 | 04:33 PM
GoFightNguyen's Avatar
GoFightNguyen
Because Racecar
Originally Posted by tmmueller
Have you searched through the official vossen wheel thread? most likely everything you need to know is in it. I also recommend PM'ing Diego as he will tell you exactly what you need to know. Lastly, the eiabach's *PROBABLY* don't require a camber kit but you will be close to running too much negative camber. Your tires will wear a bit faster is all. If you do a square set-up you may be able to rotate the tires to help prolong the life of them. Spacers should not be necessary if you get the proper wheel and tire set-up. Diego will point you in the right direction for sure.
*Fixed that for you
Old Nov 25, 2013 | 05:18 PM
goblincadet
Haha Ill probably look into a camber kit just to be safe. If I were to get coilovers, would they need a camber kit just as much? If not then I might just go for those instead of springs and camber.
Also, thanks for the information! Ill definitely PM Diego and go through the thread!
Old Nov 26, 2013 | 02:27 AM
evil-G-nius's Avatar
evil-G-nius
coils are going to need a camber kit more so than just springs. Typically people on coils drop lower than springs which would require a kit for sure.
mitchlt
Aug 20, 2015 03:44 PM
Gunit37xsedan
Aug 18, 2015 12:06 AM
zzww1251
Aug 8, 2015 06:19 PM
mbekheet
Aug 4, 2015 04:19 PM
