Help Tires for 19x10.75 rear rims?
Hey everyone,
I am having a hard time deciding what tires I should go with for my rears. I bought XXR 530 rims and my rears are 19x10.75 (weird size by XXR). I was thinking about going with either 275/35/19 or 265/30/19? My fronts are fine. What do you guys think? Appreciate any help!
Hey everyone,
What front wheels/tires and offsets are you running up there?
What offset are you running and are you dropped? If the offset is conservative you can run up to 305s on that wide rim, but 285/295 would be a good fit as well. Hopefully you've got the offset to run the bigger tires.
First of all, I had some 275/40/19 brand new from one of buddies. I decided to try those and those rubbed on my fender and I could not drive the car. So from that I am guessing to go with 265/35/19 or even go to 255/30/19? And stretching a little bit just to clear my fender situation.
My fronts are 245/40/19 with +15 offset. Which are fine with no rubbing.
Please help!
The offset I am running is +15 in the front and +35 in the rear. I am dropped on the Eibach Prokit which drops about 1.3" in the front and 0.8" in the rear.
Please help!
Please help!
Your front tire size is correct, the 45 series in front will be roughly the same diameter as the 275/40 in back.
You should be running 35 series in the rear to keep your diameter in range of your OEM diameter, so a 275/35/19 would be the proper size. You might be fine running that width if you shave the fender bracket and trim the felt wheelwell liner, that's what most of the lowered guys do to get wider wheels on a lowered G to run without rubbing.
