Will I rub?
Old Aug 14, 2013 | 02:21 PM
Himalaya's Avatar
Himalaya
Will I rub?
I am planning on buying a set of wheels and tires from someone tonight. Specs are
Front: 255/35/20 width 9 offset 25
Rear: 285/30/20 width 10.5 offset 27
I have a g37 AWD coupe. I did the math for the rolling diameter and its 1.1 percent which falls under the 3 percent rule.
wiht the offsets, would I rub or would I need spacers?
Old Aug 15, 2013 | 07:46 AM
zzeiler's Avatar
zzeiler
I bought used ones that were F:20x 9.5 +18 235/35/20 and R:20x 10.5 +24 275/35/20 and it rubbed a lot in the back, I had to stretch the rears with 255/30/20 for it to work with my coilovers and then I still had to shave the rear brackets. Good luck!
Old Aug 15, 2013 | 10:09 AM
burunet's Avatar
burunet
you'll have to trim your rear bumper bracket. I am running 255/35/20 on 20x10 +20 on the front and 285/35/20 on 20x10 +25 rear and had to shave it almost all the way, but now no rubbing whatsoever.
Old Aug 18, 2013 | 01:13 PM
R.L. ina G37's Avatar
R.L. ina G37
Just double check if you can go staggered with the AWD model. I've read and been told numerous times that's a bad idea.
BurtoN86
Nov 3, 2015 04:40 PM
Soccer4555
Sep 30, 2015 05:31 PM
Heffalump55555
Sep 26, 2015 08:02 PM
botlfed98
Sep 22, 2015 12:30 PM
Simran Mann
Sep 9, 2015 02:08 AM
