vossen cv1 tire advice
Hey guy i recently order a set of 19x8.5 and 19x10 vossen cv1 stagger setup for my 2009 g37xs sedan and im currently lost on what perfect tire size to get can anyone can please give me some help im currently on the stock 18 inch wheels
I have 245/295 setup on my dropped RWD. I would say a 245/275 or 255/285 setup would be a nice combo.
Use this tire calculator to find the best F&R tire sizes and keep in mind your new diameters F&R need to be within 3% +/- of your stock tire diameter and should be within 3% of each other from the front to the back.
BTW, any other tire/wheel questions should be posted in this section
Brakes, Suspension, Wheels & Tires - MyG37
HTHs
Ideally though, if you can change to 20s the combo that CRV has above would be perfect, the 20 wheels cost more but the tires are cheaper so in the long run the 20s end up cheaper (assuming you go through a few sets of tires).
Wheel-Tire size comparer - RIMSnTIRES.com
blnewt has been very helpful on my quest to find and fit wheels on my car.
But i agree thats the main reason why I opted to go with the 20's. When you compare the pricing of tires between the 19s vs 20s, it just makes makes sense and your wallet will thank you.
Those sizes are very close, only .14" difference and 0.52% from each others' diameter, that will be fine.
Hi Diego,
I'm new here.....
So does that mean that my stock rim/tire on a 2010 Journey Sport that has the 225/45/19 and 245/40/19 will accept those larger tires (245 and 275) on my same rims? tx
I just bought this car four days ago and lthe original? Bridgestone Potenzas are shot.
I'm new here.....
SuicidalG37SGuy
Sep 10, 2015 06:01 AM
mmnjtwa
Sep 7, 2015 02:27 PM
