Help with 2013 G37xS Handling & Tires
Old Mar 31, 2013 | 01:52 PM
dmccombs's Avatar
dmccombs
I recently got a 2013 G37xS. It has the Enkei 19x85 rims all the way around. The stock tires are All Season Advans 225/45/19.
The handling seems ok, but not great. It seems like the non-AWD G37's I drove handled better. They seemed more responsive.
I don't know if the slight difference in looseness is because of the AWD, Tires, or something else in the suspension. What do you think?
I have thought about changing the tires to Michelin Pilot Sports. What changes do you think I will see compared to the Advan A/S, in the way of:
Performance:
Handling:
Comfort:
Noise:
Any feedback from people that went from All Seasons to the Pilot Sports would be especially helpful.
Old Mar 31, 2013 | 03:15 PM
JSolo's Avatar
JSolo
Just say no!!!!!
All season tires = no season tires. Get some good summer rubber on there and it'll handle a lot differently. You might want to consider sway bars too if there's too much body roll for your liking.
Most people have gone with wider tires for the michelin PSS's. In fact, one of the items on my to do list is to try to find some feedback from those running them in stock sizes on 18" wheels (rwd S sedan).
If I don't go with the PSS's, i'll likely end up with the bridgestone S04's (also in stock size). Need a tire with a stiff side wall for good feedback.
Old Apr 1, 2013 | 10:14 AM
dmccombs's Avatar
dmccombs
Can you give more detail on what I will get going from the All Season Advans to the Summer Michilen Pilot Sports, in the ways of:
Performance:
Handling:
Comfort:
Noise:
Old Apr 1, 2013 | 01:07 PM
JSolo's Avatar
JSolo
Just say no!!!!!
Not really.
In general, performance will increase (stickier rubber), handling will also be more precise (stiffer sidewalls), comfort will decrease (see above), noise varies. I've read good reviews about the PSS's, but don't recall if that was stock size or larger.
The comments above apply to any performance tire vs all season though, and not necessarily the PSS. As a summer only tire, no performance tire should be used in the snow or extreme cold temps.
Old Apr 5, 2013 | 03:52 PM
Neal@tirerack's Avatar
Neal@tirerack
MYG37.COM Platinum Sponsor
Higher up the performance food chain you go the shorter life, stiffer ride, and more noise they will make. However, you'll gain much more steering response and dry grip. It's the opposite the closer you get to an all season tire. What percentage is subjective to the user and hard to specifically say.
Old Apr 5, 2013 | 06:28 PM
nukee26's Avatar
nukee26
Performance:
Handling:
Comfort:
Noise:
If you're looking for specific feedback like that, go to tirerack or 1010tires and read the reviews. You'll get a lot more there.
Old Apr 5, 2013 | 09:08 PM
dmccombs's Avatar
dmccombs
I did do that, but i kept finding feedback from folks with Ford Taurus' etc. and i figured that some g37x owners might have made the switch to good summer tires.
Thanks for the suggestion though.
derekjl
Oct 2, 2015 05:05 PM
sharmelan
Aug 25, 2015 03:41 PM
drkashifa
Aug 18, 2015 04:38 PM
Spicy_Kimchee
Aug 11, 2015 09:10 AM
sharmelan
Aug 6, 2015 04:29 PM
