yet another offset noob
Old Mar 14, 2013 | 02:35 AM
SunnyD89's Avatar
SunnyD89
I tried asking this elsewhere and did get one response (thank you very much blnewt!), I just wanted to see what other people would suggest.
09 sedan journey. lowered on eibach pk. 20x9 square setup. 245/35 tires. what offset should I run all around for flush without the rub?
also, couldnt help but click this ...
Old Mar 14, 2013 | 06:57 PM
SunnyD89's Avatar
SunnyD89
ok so i saw some people saying 32 offset, others say 35, others say 38, and others say 40. seem to be too many different ones out there for me to know what i should be running. also i dont think any of those people were running a 20x9 on a lowered journey.... help? anyone? pleaseee?
Old Mar 14, 2013 | 09:22 PM
Did a bit more figuring using the G37 Tire calculator, looks like you'll get the same rear flush setup as mine going w/ a +32. Keep in mind that you won't be quite as low as me so your tires will be out a couple mm but will tuck into the fender wells when compressed. If you go w/ +32 in the front you'll get inside the fender but the lack of a true roll on the under fender lip may cause rubbing under compression.
Here's a pic of my rear "flushness" and this is at -1.2 degrees camber
Old Mar 14, 2013 | 09:57 PM
SunnyD89's Avatar
SunnyD89
you are my hero.
ck1109
Oct 15, 2015 11:06 PM
rk325
Oct 13, 2015 01:51 PM
Kojack
Oct 9, 2015 05:53 PM
bobtaz13
Oct 1, 2015 01:39 PM
VIVID
Sep 27, 2015 09:45 AM
