Vibrations while driving
Old Dec 15, 2012 | 01:45 PM
quakerroatmeal's Avatar
quakerroatmeal
These are hub rings..they're normally plastic and go on the back of the wheel. Discount Tire should be able to get you some / or have some in stock.
Old Dec 15, 2012 | 08:37 PM
Topher9425's Avatar
Topher9425
Anyone know the dimensions of hub rings needed for our cars and Stance wheels?
Old Dec 15, 2012 | 11:41 PM
TVPostSound's Avatar
TVPostSound
Does the vibration ease off as you pass 80mph?
Then it's the wheel balance.
Old Dec 16, 2012 | 12:01 AM
nanotech's Avatar
nanotech
If doscount tire does the hub rings then that would be awesome!! Because I bought my tires from there and I can get my balance and the hub ring thing done there at the same time! And I haven't gotten passed 80 mph so I don't know.
Old Dec 17, 2012 | 09:36 PM
nanotech's Avatar
nanotech
Thanks for all the help. I talked to discount tire and I'm getting a balance done with Hub Rings installed tomorrow.
Old Dec 17, 2012 | 10:02 PM
JohnnysG's Avatar
JohnnysG
Why get a balance done when the hub rings are most likely the cause of your issue? You're wasting $
Old Dec 17, 2012 | 10:18 PM
nanotech's Avatar
nanotech
It is free. i bought my tires from there with warranty so not wasting any money. But thanks.
Old Dec 18, 2012 | 10:17 AM
Diego@Vossen's Avatar
Diego@Vossen
If you are missing hub rings lmk, i will send you 4 today. For future reference our center bore is 66.1 and hub rings needed are 73.1 to 66.1!
Old Dec 18, 2012 | 12:21 PM
nanotech's Avatar
nanotech
Thanks but I already got some from discount tire. They took my wheels measurements and had some in stock so I think I'm good. But is 66.1-73.1 like the hub ring measurements? I've never done hub rings before so I really have no idea.
Old Dec 18, 2012 | 12:29 PM
Topher9425's Avatar
Topher9425
Diego...you can hook me up if you can!
Old Dec 18, 2012 | 12:32 PM
ECain18's Avatar
ECain18
our center bore that our stock wheels mount over is 66.1. They are exact fit so you dont need a hub ring. Your wheels are 73.1, which is bigger so they can fit on multiple different vehicles (each manufacturer is different). As such, you need a spacer that fills that void, which is what the hub ring does and will stop the vibrations
Old Dec 18, 2012 | 12:33 PM
ECain18's Avatar
ECain18
I would get aluminum rings over the plastic ones. Just a personal preference but seems much stronger to me. Not sure it really matters all that much tho
Old Dec 18, 2012 | 12:37 PM
Diego@Vossen
There is an outer and inner to hub ring measurements. 73.1 is outer to 66.1 inner.
Old Dec 18, 2012 | 04:36 PM
  #29
nanotech's Avatar
nanotech
Thanks! I will make sure discount tire have these same measurements.
tt350z
Sep 22, 2015 12:05 PM
claudiohv
Sep 17, 2015 01:43 AM
sharmelan
17
Sep 14, 2015 03:18 PM
rgonz
Sep 11, 2015 04:07 PM
SuicidalG37SGuy
Sep 10, 2015 06:01 AM
